I have just installed the current stable release of OSSEC (2.8.1) for Ubuntu, but at the end of the installation I noticed that it said:
- System is Debian (Ubuntu or derivative).
 - Init script modified to start OSSEC HIDS during boot.
 - Configuration finished properly.
 - To start OSSEC HIDS:
        /var/ossec/bin/ossec-control start
 - To stop OSSEC HIDS:
        /var/ossec/bin/ossec-control stop
 - The configuration can be viewed or modified at /var/ossec/etc/ossec.conf
So what is OSSEC HIDS, is it the actual program or something else? If it is the actual program then does this mean that I need to add the command /var/ossec/bin/ossec-control start to the list of startup applications?
Information Update:
I have found that unless I run this command to manually start OSSEC HIDS:
sudo /var/ossec/bin/ossec-control start
That if I run the command to check the status:
sudo /var/ossec/bin/ossec-control status
This is the output:
ossec-monitord not running...
ossec-logcollector not running...
ossec-syscheckd not running...
ossec-analysisd not running...
ossec-maild not running...
ossec-execd not running...
So it does not seem that it starts automatically, how can I get it to do this then? I have also found that I cannot add this to the list of startup applications as the start command requires sudo to be executed.
OS Information:
Description:    Ubuntu 14.10
Release:    14.10
OSSEC = Open Source SECurity
HIDS = host-based intrusion detection system (HIDS)
http://www.ossec.net/
OSSEC is an Open Source Host-based Intrusion Detection System that performs log analysis, file integrity checking, policy monitoring, rootkit detection, real-time alerting and active response.
From the message, OSSEC will automatically start on boot and runs as a service in the back ground.
To manually start or stop use
sudo /var/ossec/bin/ossec-control stop
you do not need to do anything else.
See also http://ubuntuforums.org/showthread.php?t=213445
Although it is possible my forums post may be a bit dated, for the most part it should help. If there is a problem with the post, post in the forums.
Panther
  • 104,528
Not sure if you fixed this or not, but if you are still using 14.10 then you can try this:
sudo nano /etc/init.d/ossec
copy this:
 #!/bin/sh
case "$1" in
start)
stop)
restart)
  $0 stop && sleep 3
  $0 start
reload)
  $0 stop
  $0 start
echo "Usage: $0 {start|stop|restart|reload}"
exit 1
esac
Ctrl+o (save) Crtl+x (exit)
sudo chmod +x /etc/init.d/ossec
sudo update-rc.d ossec defaults
Test: sudo /etc/init.d/ossec start
Hope this helps.
Adathor
  • 61
One way to run OSSEC at startup is to add the start command to /etc/rc.local before the exit 0 line and after #! /bin/sh. Though this is no longer necessary now that OSSEC supports systemd.
muru
  • 207,228
