I would like to ask people, who own new BQ's Aquaris E4.5 Ubuntu edition about their experience with battery life. Or other people, what should I do, if there is any problem with mine. Because the battery life seems to me really really really low. I have to charge it everyday, even though I barely use it. I charge to 100%, go to sleep and when I wake up next morning, there is around 70% left. Is it normal, that it losts 30% of battery just by being there on my table? I go to school, the same, it's there in my pocket the whole day and when I get home, I have to charge it, because it won't last until the next morning. Is there anything I can do or it's just normal with this phone / OS? This is basically the only thing that bothers me about BQ's Ubuntu Phone. Except that it's a great phone.
Thank you for your answers.
Denco
  • 33
6 Answers6
You are currently seeing excessive drain due to issues with GPS being overly active and the notification daemon keeping the system awake, along with a few other things.
The upcoming system update has a number of changes to greatly improve the battery life. We are working to release this update at the earliest possible time, sorry for the inconvenience.
A list of these fixes is at https://bugs.launchpad.net/canonical-devices-products/+bugs?field.tag=battery&field.status%3Alist=FIXRELEASED
Pat
  • 126
Personally I use it every day basically for seeing my mails, twitter, the news and some calls/sms, and with the wifi on at home or the 3G outside and the position off, my battery lasts for 24-36h. It's like full in the morning and about 40-50% left at night
AdricoM
  • 111
I have similar "features", my battery lasts about 24 hrs with normal use and it is really not influenced by the screen as much as it is by the wi-fi and 3G antenna.
This obviously means that during a 8hr sleep it goes down by about 30% (8 hours is about 1/3 of a day, 24 hours ;) ) if I do not switch off wi-fi and 3G.
I have experienced that the wi-fi is the thing that uses the most battery. Try turning it off when you don't use it; this will save a lot of power.
And, if you can, remember to switch to 2G whenever you don't need 3G.
dadexix86
  • 6,776
I have been using mine for a while now. After 2 days of use It usually still has about 20-5% battery left.
My usage pattern:
  • Hook it up to the charger before I go to sleep (I turn of the wifi at night).
  • Turn on the wifi in the morning.
  • Use it normally during the day - 3-4 calls/day, wifi off if I'm on the PC, wifi on during other times. Bluetooth is on during commute time (a little less than 1h/day)
  • Turn of wifi while I sleep
  • Same cylce next day - but at the second night I have to charge it again.
Notes:
I normally do some browsing on the phone during the day, but it's mostly email, hangups via terminal and a few scopes.
Stunts
  • 2,262
My Ubuntu phone has good days and bad days. Often areas of poor reception and losing signal+finding new networks drains the battery, which is probably why it drains quicker in the countryside and underground.
I find turning off services like location and GPS can help, and wifi is a massive drain.
I know the next RTM release is going to bring some improvements to battery life, should be out in the coming weeks.
user1628
  • 427
My battery sucks hairy ones, and it appears to be getting worse. Last night I charged it around evening time, I made sure to do all my downloads + browsing while charging so as not to overwork when off charger. It is now at 20% and says "last full charge 14 hours", I always have GPS off & usually before bed I make sure to close all apps, but left habitRPG on last night, perhaps this is why it is so bad today...
I like this phone, but there are a few frustrating issues, I am hoping the positives will out weigh the negatives.
Is there any battery saving app about that will help save power? I had one on my android that I could set up schedules: Wifi, bluetooth, GPS off at night and back on in morning. A scope or app that tells you where power is going would be good, with option to close power drainers.
Corp
  • 186
