I want to install Windows 10 Technical Preview. I have downloaded its .iso file. Now I want to make a flash drive bootable. How can I do that?
I already have tried these 2 options.
  1. Making a bootable pendrive via dd command, but it's not working.
    sudo umount /dev/sdb
    sudo dd if=/path/to/windows10.iso of=/dev/sdb bs=1M && sync
  2. I also have tried using WinUSB, but it's not working either.
    sudo add-apt-repository ppa:colingille/freshlight
    sudo sh -c "sed -i 's/trusty/saucy/g' /etc/apt/sources.list.d/colingille-freshlight-trusty.list"
    sudo apt-get update
    sudo apt-get install winusb
It was just running a process showing a message that it's formatting the USB stick, but that didn't last for 20 minutes!! And I had to cancel it.
Is there any way I can make a bootable pendrive for installing Windows 10 from Ubuntu 14.04?
Apurva
  • 451
use unetbootin! easy, fast, with GUI, give it a try! ;)
or right click on win10 image, open with disk image mounter, and copy all to your bootable pen. make sure it's empty on either way, you can use "disks"* from ubuntu, have a look on youtube, lots of ways to do that (just look for any windows image, it's all the same) ;)
*disks: select your pendrive, unmount, click on the wheels, format, fat32 (it'll say lba initializable), then copy or use unetbootin!
