11
I would like to remove several of the Indicators that usually appear in the upper-right-hand side of the login screen. In particular, I would like to remove the accessibility, keyboard layout, power, and sound indicators, although it would be nice to know how to generically add or remove indicators. How can I do this?
fouric
  • 4,698
One way that I have tried in Ubuntu 14.04 using LightDM (Default); Using Some config files stored in /usr/share/unity/indicators/
Let's say you want to hide keyboard indicator:
  1. Open corresponding file for editing
    sudo nano /usr/share/unity/indicators/com.canonical.indicator.keyboard
  2. Comment object paths for the mode you want to hide in, example this will hide it in the greeting screen and lock screen
    [Indicator Service]
    Name=indicator-keyboard
    ObjectPath=/com/canonical/indicator/keyboard
    Position=80
    [desktop]
    ObjectPath=/com/canonical/indicator/keyboard/desktop
    #[desktop_greeter]
    #ObjectPath=/com/canonical/indicator/keyboard/desktop_greeter
    #[desktop_lockscreen]
    #ObjectPath=/com/canonical/indicator/keyboard/desktop_lockscreen
    [ubiquity]
  3. Reboot or just restart display manager
    sudo service lightdm restart
user.dz
  • 49,176
Coming with different approach:
$ pstree
init─┬─...
     ├─lightdm─┬─Xorg
     │         ├─lightdm─┬─lightdm-greeter───unity-greeter───4*[{unity-greeter}]
$ dpkg -L unity-greeter
/usr/share/glib-2.0/schemas/com.canonical.unity-greeter.gschema.xml
$ more /usr/share/glib-2.0/schemas/com.canonical.unity-greeter.gschema.xml
    <key name="indicators" type="as">
      <default>['ug-accessibility', 'com.canonical.indicator.keyboard', 'com.canonical.indicator.session', 'com.canonical.indicator.datetime', 'com.canonical.indicator.
power', 'com.canonical.indicator.sound', 'application']</default>
      <summary>Which indicators to load</summary>
    </key>
unity-greeter is run by lightdm user! Instead of looking around for a way to change the dconf setting for that ghost user. I override the default. Tested in Ubuntu 14.04 64bit (VirtualBox).
  1. Create new dconf override file
    sudo nano /usr/share/glib-2.0/schemas/90_unity-greeter.gschema.override
    Put these two lines in it with indicator you want to keep:
    [com.canonical.unity-greeter]
    indicators=['com.canonical.indicator.session']
    Default is:
    ['ug-accessibility', 'com.canonical.indicator.keyboard', 'com.canonical.indicator.session', 'com.canonical.indicator.datetime', 'com.canonical.indicator.power', 'com.canonical.indicator.sound', 'application']
  2. Recompile glib schemas
    sudo glib-compile-schemas /usr/share/glib-2.0/schemas/
  3. Restart the display manager
user.dz
  • 49,176
