I installed ubuntu 14.10 and it boots slow.
I searched the web and found some research about checking the dmesg, i did so and i found out there was some problems with my Bluetooth and i solved that.
But as you can see at the code there are many other errors that i can not solve and i need help with solving them.
The log shows ACPI ERROR
Firmware Bug
and some kind of error with nouveau.
[ 15.927681] ACPI: Video Device [PEGP] (multi-head: yes rom: yes post: no)
[ 15.936316] acpi device:4d: registered as cooling_device9
[ 15.971669] ACPI Error: [\_SB_.PCI0.LPCB.EC0_.BLVL] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 15.971674] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0.PEGP.DD01._BQC] (Node ffff880362066d48), AE_NOT_FOUND (20140424/psparse-536)
[ 15.971681] ACPI Warning: Evaluating _BQC failed (20140424/video-779)
[ 16.104048] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
[ 16.119451] audit: type=1400 audit(1427988997.424:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=504 comm="apparmor_parser"
[ 16.119457] audit: type=1400 audit(1427988997.424:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=504 comm="apparmor_parser"
[ 16.119460] audit: type=1400 audit(1427988997.424:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=504 comm="apparmor_parser"
[ 16.119469] audit: type=1400 audit(1427988997.424:5): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/sbin/dhclient" pid=432 comm="apparmor_parser"
[ 16.119474] audit: type=1400 audit(1427988997.424:6): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=432 comm="apparmor_parser"
[ 16.119478] audit: type=1400 audit(1427988997.424:7): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=432 comm="apparmor_parser"
[ 16.119488] audit: type=1400 audit(1427988997.424:8): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/sbin/dhclient" pid=501 comm="apparmor_parser"
[ 16.119494] audit: type=1400 audit(1427988997.424:9): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=501 comm="apparmor_parser"
[ 16.119498] audit: type=1400 audit(1427988997.424:10): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=501 comm="apparmor_parser"
[ 16.235938] ACPI Error: [\_SB_.PCI0.LPCB.EC0_.BLVL] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 16.235944] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0.PEGP.DD01._BCM] (Node ffff880362066d70), AE_NOT_FOUND (20140424/psparse-536)
[ 16.235952] ACPI Error: Evaluating _BCM failed (20140424/video-384)
[ 16.312047] ACPI Error: [\_SB_.PCI0.LPCB.EC0_.BLVL] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 16.312053] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0.PEGP.DD02._BQC] (Node ffff880362066eb0), AE_NOT_FOUND (20140424/psparse-536)
[ 16.312060] ACPI Warning: Evaluating _BQC failed (20140424/video-779)
[ 16.320074] ACPI Error: [\_SB_.PCI0.LPCB.EC0_.BLVL] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 16.320079] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0.PEGP.DD02._BCM] (Node ffff880362066ed8), AE_NOT_FOUND (20140424/psparse-536)
[ 16.320085] ACPI Error: Evaluating _BCM failed (20140424/video-384)
[ 16.336036] ACPI Error: [\_SB_.PCI0.LPCB.EC0_.BLVL] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 16.336041] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0.PEGP.DD03._BQC] (Node ffff88036206c050), AE_NOT_FOUND (20140424/psparse-536)
[ 16.336046] ACPI Warning: Evaluating _BQC failed (20140424/video-779)
[ 16.344078] ACPI Error: [\_SB_.PCI0.LPCB.EC0_.BLVL] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 16.344083] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0.PEGP.DD03._BCM] (Node ffff88036206c078), AE_NOT_FOUND (20140424/psparse-536)
[ 16.344088] ACPI Error: Evaluating _BCM failed (20140424/video-384)
[ 16.360056] ACPI Error: [\_SB_.PCI0.LPCB.EC0_.BLVL] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 16.360061] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0.PEGP.DD04._BQC] (Node ffff88036206c1e0), AE_NOT_FOUND (20140424/psparse-536)
[ 16.360066] ACPI Warning: Evaluating _BQC failed (20140424/video-779)
[ 16.368073] ACPI Error: [\_SB_.PCI0.LPCB.EC0_.BLVL] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 16.368078] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0.PEGP.DD04._BCM] (Node ffff88036206c208), AE_NOT_FOUND (20140424/psparse-536)
[ 16.368084] ACPI Error: Evaluating _BCM failed (20140424/video-384)
[ 16.384045] ACPI Error: [\_SB_.PCI0.LPCB.EC0_.BLVL] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 16.384050] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0.PEGP.DD05._BQC] (Node ffff88036206c370), AE_NOT_FOUND (20140424/psparse-536)
[ 16.384056] ACPI Warning: Evaluating _BQC failed (20140424/video-779)
[ 16.392127] ACPI Error: [\_SB_.PCI0.LPCB.EC0_.BLVL] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 16.392132] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0.PEGP.DD05._BCM] (Node ffff88036206c398), AE_NOT_FOUND (20140424/psparse-536)
[ 16.392139] ACPI Error: Evaluating _BCM failed (20140424/video-384)
[ 16.416143] ACPI Error: [\_SB_.PCI0.LPCB.EC0_.BLVL] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 16.416149] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0.PEGP.DD06._BQC] (Node ffff88036206c500), AE_NOT_FOUND (20140424/psparse-536)
[ 16.416154] ACPI Warning: Evaluating _BQC failed (20140424/video-779)
[ 16.424155] ACPI Error: [\_SB_.PCI0.LPCB.EC0_.BLVL] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 16.424159] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0.PEGP.DD06._BCM] (Node ffff88036206c528), AE_NOT_FOUND (20140424/psparse-536)
[ 16.424165] ACPI Error: Evaluating _BCM failed (20140424/video-384)
[ 16.444158] ACPI Error: [\_SB_.PCI0.LPCB.EC0_.BLVL] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 16.444163] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0.PEGP.DD07._BQC] (Node ffff88036206c690), AE_NOT_FOUND (20140424/psparse-536)
[ 16.444168] ACPI Warning: Evaluating _BQC failed (20140424/video-779)
[ 16.452174] ACPI Error: [\_SB_.PCI0.LPCB.EC0_.BLVL] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 16.452179] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0.PEGP.DD07._BCM] (Node ffff88036206c6b8), AE_NOT_FOUND (20140424/psparse-536)
[ 16.452185] ACPI Error: Evaluating _BCM failed (20140424/video-384)
[ 16.504323] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:4c/LNXVIDEO:00/input/input13
[ 16.504439] [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
[ 16.504444] [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
[ 16.504448] [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
[ 16.504453] [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
[ 16.504458] [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
[ 16.514922] MXM: GUID detected in BIOS
[ 16.514952] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20140424/nsarguments-95)
[ 16.514962] ACPI: \_SB_.PCI0.PEG0.PEGP: failed to evaluate _DSM
[ 16.514979] checking generic (a0000000 7e9000) vs hw (a0000000 10000000)
[ 16.514980] fb: switching to nouveaufb from EFI VGA
[ 16.515005] Console: switching to colour dummy device 80x25
[ 16.515217] nouveau [ DEVICE][0000:01:00.0] BOOT0 : 0x0e70d0a2
[ 16.515219] nouveau [ DEVICE][0000:01:00.0] Chipset: GK107 (NVE7)
[ 16.515220] nouveau [ DEVICE][0000:01:00.0] Family : NVE0
[ 16.515236] nouveau [ VBIOS][0000:01:00.0] checking PRAMIN for image...
[ 16.515241] nouveau [ VBIOS][0000:01:00.0] ... signature not found
[ 16.515242] nouveau [ VBIOS][0000:01:00.0] checking PROM for image...
[ 16.515299] nouveau [ VBIOS][0000:01:00.0] ... signature not found
[ 16.515300] nouveau [ VBIOS][0000:01:00.0] checking ACPI for image...
[ 16.769444] EXT4-fs (sda9): re-mounted. Opts: errors=remount-ro
[ 16.997419] init: Error while reading from descriptor: Broken pipe
[ 16.998725] init: failsafe main process (723) killed by TERM signal
[ 17.208472] audit: type=1400 audit(1427988998.512:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=799 comm="apparmor_parser"
[ 17.259568] init: avahi-cups-reload main process (838) terminated with status 1
[ 19.038170] nouveau 0000:07:00.0: enabling device (0006 -> 0007)
[ 19.038353] nouveau [ DEVICE][0000:07:00.0] BOOT0 : 0x0e70d0a2
[ 19.038355] nouveau [ DEVICE][0000:07:00.0] Chipset: GK107 (NVE7)
[ 19.038356] nouveau [ DEVICE][0000:07:00.0] Family : NVE0
[ 19.038378] nouveau [ VBIOS][0000:07:00.0] checking PRAMIN for image...
[ 19.038386] nouveau [ VBIOS][0000:07:00.0] ... signature not found
[ 19.038387] nouveau [ VBIOS][0000:07:00.0] checking PROM for image...
[ 19.108025] nouveau [ VBIOS][0000:07:00.0] ... appears to be valid
[ 19.108026] nouveau [ VBIOS][0000:07:00.0] using image from PROM
[ 19.108105] nouveau [ VBIOS][0000:07:00.0] BIT signature found
[ 19.108107] nouveau [ VBIOS][0000:07:00.0] version 80.07.a8.00.32
[ 19.108428] nouveau [ DEVINIT][0000:07:00.0] adaptor not initialised
[ 19.108444] nouveau [ VBIOS][0000:07:00.0] running init tables
[ 19.423949] nouveau 0000:07:00.0: irq 50 for MSI/MSI-X
[ 19.423957] nouveau [ PMC][0000:07:00.0] MSI interrupts enabled
[ 19.423998] nouveau [ PFB][0000:07:00.0] RAM type: GDDR5
[ 19.423999] nouveau [ PFB][0000:07:00.0] RAM size: 2048 MiB
[ 19.424000] nouveau [ PFB][0000:07:00.0] ZCOMP: 0 tags
[ 19.425914] nouveau [ VOLT][0000:07:00.0] GPU voltage: 600000uv
[ 19.455486] nouveau [ PTHERM][0000:07:00.0] FAN control: none / external
[ 19.455493] nouveau [ PTHERM][0000:07:00.0] fan management: automatic
[ 19.455503] nouveau [ PTHERM][0000:07:00.0] internal sensor: yes
[ 19.455534] nouveau [ CLK][0000:07:00.0] 07: core 405 MHz memory 810 MHz
[ 19.455587] nouveau [ CLK][0000:07:00.0] 0a: core 405-1097 MHz memory 1600 MHz
[ 19.455657] nouveau [ CLK][0000:07:00.0] 0f: core 405-1097 MHz memory 5400 MHz
[ 19.455794] nouveau [ CLK][0000:07:00.0] --: core 405 MHz memory 810 MHz
[ 19.488550] nouveau E[ PBUS][0000:07:00.0] MMIO write of 0x00000002 FAULT at 0x4188ac [ IBUS ]
[ 19.488641] nouveau [ DRM] VRAM: 2048 MiB
[ 19.488642] nouveau [ DRM] GART: 1048576 MiB
[ 19.488644] nouveau [ DRM] TMDS table version 2.0
[ 19.488645] nouveau [ DRM] DCB version 4.0
[ 19.488647] nouveau [ DRM] DCB outp 01: 08011f82 00020010
[ 19.488648] nouveau [ DRM] DCB outp 02: 02044f00 00000000
[ 19.488649] nouveau [ DRM] DCB conn 01: 01000161
[ 19.488650] nouveau [ DRM] DCB conn 04: 00000400
[ 19.489720] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 19.489721] [drm] Driver supports precise vblank timestamp query.
[ 19.495906] nouveau [ DRM] MM: using COPY for buffer copies
[ 19.495914] [drm] Initialized nouveau 1.1.2 20120801 for 0000:07:00.0 on minor 1
[ 21.392326] init: plymouth-upstart-bridge main process ended, respawning
[ 21.396146] init: plymouth-upstart-bridge main process ended, respawning
[ 21.410315] systemd-logind[933]: Failed to start unit user@112.service: Unknown unit: user@112.service
[ 21.410319] systemd-logind[933]: Failed to start user service: Unknown unit: user@112.service
[ 21.412703] systemd-logind[933]: New session c1 of user lightdm.
[ 21.412714] systemd-logind[933]: Linked /tmp/.X11-unix/X0 to /run/user/112/X11-display.
[ 26.586321] systemd-logind[933]: Failed to start unit user@1000.service: Unknown unit: user@1000.service
[ 26.586326] systemd-logind[933]: Failed to start user service: Unknown unit: user@1000.service
How can i solve the Nouveau problem?
