When I go into the network settings in Ubuntu Gnome 14.10 (Which I heard is now a official flavour of Ubuntu) it usually says it's connected but at 10Mbs which is extremely slow and barely scratches the surface of my 30Mbs speed. I know my Ethernet card is capable of connecting up to 1Gbs! When I turn off the Ethernet and turn it back on, it just puts it back at 10Mbs! Once I unplug the cable and put it back in, it says "Cable Unplugged" when it's plugged in! My Ethernet card is a Realtek 8111 I think. Here is a pastebin for what is says for.
sudo lshw -C network
A.B.
  • 92,125
Jacky
  • 197
10Mbps is standard fall-back mode for when things are not quite clicking as they should. Causes could be either:
  • NIC of the laptop
  • network cable used is defective or with strange wiring or not crimped well
  • port on the switch you're connecting is bad
It would be best if you can try plugging the laptop with same cable on a known good switch port and see what it gives you, then replace the cable, until you find root cause.
Eliah Kagan
  • 119,640
I just turned off the computer, removed the battery and left it for 15 minutes. Then it jumped back to 1Gbps.
Jacky
  • 197
