I accidently ran sudo rm *
I thought I was in an unimportant subfolder.
The result is that I deleted some very important files. Is there any way to get my data back?
Zanna
  • 72,312
But I prefer foremost
Install foremost
sudo apt-get install foremost
Take a look at
man foremost
to learn how to use foremost.
First make an empty writable directory to save recover files in a partition other than that you are going to recover.
Then run foremost.
I am going to recover my home partition ( let's say /dev/sda5).
$ sudo foremost -t jpg -i /dev/sda5 -o /recovery/data
Finally set user permission to /recovery/data/ to view image. type
$ sudo chown YOUR_USER_NAME /recovery/data -R
Some important foremost command line arguments.
-i  :- partition/image to recover
-o :- location to store recovered files.
-t  :- built in file filter options.  you can give multiple filters by separating using commas. (e.g: for jpg and pdf: -t jpg,pdf )
-q :- quick mode.
2707974
  • 10,758
After the steps from @2707974 above, then you can use this bash utility lines to browse millions of files quickly and painless, something like this:
`$ mkdir /recovery/filtered && cd /recovery/data && SKIP=1300 #SKIP value depends on your needs
$ for((j=$SKIP; j<10000; j=j+100)); do
   for i in $(ls -S . | head -n $j | tail -n 100); do
     cp $i ../filtered/;
   done;
   sleep 10;
   rm ../filtered/*;
done`
And then now, you can open /recovery/filtered on your file browser, and watch your history...
mboyar
