I have a Toshiba laptop with a touchscreen that is cracked and messed up. How do I disable my touch screen in Ubuntu 14.04.2?
You will need to run xinput command to determine what's your touchscreen's id is, and then make xinput disable x run on every boot, where x is the id number. Source: https://askubuntu.com/a/581334/295286
I have also seen that, run (xinput –list) Identify touch screen from the list produced
Then run the following line to disable: xinput –disable “Name Of Your Touch Screen”
Running this line will enable it: xinput –enable “Name Of Your Touch Screen”
Phil UK
  • 1,397
this script works for me. my Hp Envy 360 touch screen cracked after an accident but the main screen works fine (so far)
\#!/bin/bash
OIFS=$IFS
\# note that the pen didnt show up until I mapped the standard one or clicked the screen. - [ this comment only relevant for digitiser pens.]
\# so need to do that first
list=$(xinput | grep $search | grep pointer)
echo "list $list"
\# extract the ids from the list, id's are needed and can change at the next login/boot
\# my Hp envy touchscreen is ELAN0732:00 which is the first column  of # "xinput" .
 Change it to yours here
device_id=$(echo "$list" | sed -n 's/.*ELAN0732:00.*id=\
([0-9]*\).*/\1/p')
for i in $device_id
do
echo "id is $i"
xinput disable $i
done
save the script, make it executable, super key, type start , select startup applications, select add, give it a name, command is -
bash "/yourpath/yourscriptname.sh"
pierrely
  • 725
