How do I delete my wifi driver or something else to permanently disable wifi?
I do not want to blacklist, or use security I want it deleted. I want to KEEP my wired networking.
Thanks
THIS IS NOT A DUPLICATE AS I WANT TO DELETE NOT DISABLE
I believe the best method is to blacklist the driver because if you need to use it in the future you simply unblacklist it and you are back online.
Run this command and it will tell you the driver your device is using:
lspci -nnk | grep -iA2 net
then run:
echo "blacklist driver name" | sudo tee -a /etc/modprobe.d/blacklist.conf
You put your devices driver name in the command were driver name is now. To unblacklist the driver run:
sudo sed 's/blacklist driver name//' -i /etc/modprobe.d/blacklist.conf
please note that your driver name will not have any spaces in it.
You didn't tell anything about your hardware, but both my Dell and Lenovo laptops have a physical switch to enable/disable wifi :) That would be the easiest way.
On my HP laptop (granted, it's a business laptop and I don't think a lot of consumer laptops have the second option I'm about to tell you about) I can disable wifi with a hardware switch and even remove the wifi module through a hatch in the bottom of the laptop just like the hard drive and ram can be removed or changed.
Usually wifi also can be disabled in the bios settings, so look for this if you can't physically remove any module. If you disable wifi in the bios settings, the OS and any software running on the OS can't do anything about it.
