I was trying to make a VNC server in my Ubuntu 11.04, which can allow me to login even system reboots. Therefore, I have tried as following, but from vncviewer I can't connect.
Server listening
  1. Install
    $ sudo -s
    # apt-get install vnc4server xinetd
  2. Security
    # vncpasswd /root/.vncpasswd
    Password:
    Verify:
  3. As a service
    # vim /etc/xinetd.d/Xvnc
    service Xvnc
        type = UNLISTED
        disable = no
        socket_type = stream
        protocol = tcp
        wait = yes
        user = root
        server = /usr/bin/Xvnc
        server_args = -inetd :1 -query localhost -geometry 1024x768 -depth 16 -once -fp /usr/share/X11/fonts/misc -DisconnectClients=0 -NeverShared passwordFile=/root/.vncpasswd
        port = 5901
  4. Start the service
    # service xinetd stop
    # service xinetd start
Client trying
$ vncviewer 192.168.1.125:1
TigerVNC Viewer for X version 1.0.90 - built May 10 2011 10:04:22
Copyright (C) 2002-2005 RealVNC Ltd.
Copyright (C) 2000-2006 TightVNC Group
Copyright (C) 2004-2009 Peter Astrand for Cendio AB
See http://www.tigervnc.org for information on TigerVNC.
Wed Sep  7 10:08:20 2011
 CConn:       connected to host 192.168.1.125 port 5901
 main:        read: Connection reset by peer (104)
You might want to try x11vnc - a very powerful, relatively easy to use solution.
Please see my previous answer on a similar topic for more info. That answer also points towards a number of different ways to set x11vnc up as a service on login. I have this working for my own personal server and it's been completely reliable.
Scaine
  • 11,229
I'm expecting that you already install vnc-server and xinetd only you have you do the following
 iptables –I INPUT -p tcp --dport 5900 -j ACCEPT
 chkconfig vncserver on
 server vncserver restart
reboot then try on other PC if it's working.
reboot
if you want to access outside make sure you allow the traffic from port 5900 of your Router with the IP address of your VNC server.
devav2
  • 37,290
