14
I'm looking for a good code snippet manager, with syntax highlighting and search capabilities. Another important feature is the capability of changing the code area background color. I have tested some Adobe Air apps that had white background everywhere, which hurts my eyes.
I'm using KDE btw. I use Kate for coding, but I don't like it's snippet plugin.
lovinglinux
  • 6,427
11 Answers11
If you're working in python, Acire is a good choice.
acire
First, you need to install the Python Snippets library
sudo add-apt-repository ppa:python-snippets-drivers/python-snippets-daily
sudo apt-get update
sudo apt-get install python-snippets
Then you can install Acire itself:
sudo add-apt-repository ppa:acire-team/acire-releases
sudo apt-get update
sudo apt-get install acire
I'm using Eclipse, which has a really nice snippet manager, with support for variables and drag-and-drop.
lovinglinux
  • 6,427
instead of kate i recommend you Gvim and the SnipMate plugin, it's highly customizable, and really easy to use. Greetings
forellana
  • 303
You should try Code Barrel. It is cloud based so you can get your snippets anywhere. Oh, and it's free.
keird
This is old, but I thought i'd add: http://code.google.com/p/snippely/
I hate AIR apps, but this one was an exception. It's well designed and works well.
Oscar Godson
  • 1,695
If you're still looking for a good snippet manager tool, may I recommend QSnipps. It's cross-platform, has syntax highlighting, supports database share across all your computers.. etc.
Give it a try at: http://www.qsnipps.com/
Gabi
For the benefit of others, try gistboxapp, this is an extension for Chrome. You can use this in any platform. It is very light.
hg8
  • 13,582
lonestar
  • 111
I recommend Molimentum Quick (disclaimer: I'm the founder). It's available for Ubuntu. You can insert code snippets with ease with some shortcuts (check out the "smart insert" feature in docs). You can then click a shortcut, search, and it's copied to the clipboard. It supports syntax highlighting and because of the versatile design, it works in every editor. It also supports a dark theme.
Use a post-it application, like TomBoy or GNote. It's light and nice and stays in the panel at the top.
I would recommend Snip2Code - http://www.snip2code.com.
It allows the user to collect, organize and share code snippets, from the web site as well as directly within the preferred IDE (Visual Studio, Eclipse, IntelliJ, Notepad++) or through the native apps for Windows8 and Mac OS X.
Check it out!
Well Here are Some Really good , Colur full and light softwares: bluefish gedit(comes with default geany emacs qt creator and many more
user49557
  • 498
