This is on an Ubuntu 12.04 Server.
I'm getting this error when trying to run any apt-get install (trying to install unrelated, arbitrary packages):
dpkg: dependency problems prevent configuration of openssh-server:
openssh-server depends on openssh-client (= 1:5.9p1-5ubuntu1.1); however:
Version of openssh-client on system is 1:5.9p1-5ubuntu1.4.
dpkg: error processing openssh-server (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency probms prevent configuration of ssh:
ssh depends on openssh-server; however:
Package openssh-server is not configured yet.
dpkg: error processing ssh (--configure):
Errors were encounter while processing:
openssh-server
ssh
Installing the client version in question leads to:
sudo apt-get install openssh-client=1:5.9p1-5ubuntu1.1
Reading package lists... Done
Building dependency tree
E: Version '1:5.9p1-5ubuntu1.1' for 'openssh-client' was not found
Various attempts to fix it with lack of background knowledge failed, e.g.
dpkg-reconfigure -a
apt-get -f install
Can somebody give advice how to tackle the problem, possibly demanding more infos that are necessary from my side?
How can the openssh update (that I guess failed) be reverted or taken out of focus, so I am able to install other packages?
Edit:
Output of apt-cache policy openssh-client is:
openssh-client:
Installed: 1:5.9p1-5ubuntu1.4
Candidate: 1:5.9p1-5ubuntu1.4
Version table:
*** 1:5.9p1-5ubuntu1.4 0
500 http://archive.ubuntu.com/ubuntu/ precise-updates/main amd64 Packages
100 /var/lib/dpkg/status
1:5.9p1-5ubuntu1.3 0
500 http://security.ubuntu.com/ubuntu/ precise-security/main amd64 Packages
1:5.9p1-5ubuntu1 0
500 http://archive.ubuntu.com/ubuntu/ precise/main amd64 Packages
Just for completeness the /etc/apt/sources.list:
deb http://archive.ubuntu.com/ubuntu precise main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu precise-updates main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu precise-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu precise-security main restricted universe multiverse
