Yesterday the internet connection was working correctly and I accepted software updates.
Today I can reach the default gateway and the DNS servers (8.8.8.8), but no internet address such as www.google.com through ping. No browser or internet service (dropbox) is working. I've checked the ethernet cable and the wireless connection.
The laptop is a macbook pro 2007 running Ubuntu 14.04 with triple boot.
The network connection works perfectly form the windows 8.1 installation.
Any hint on how to get internet connection on Ubuntu again?
Ubuser
  • 53
How does your /etc/resolv.conf file look like?
Try this command: sudo echo "nameserver 8.8.8.8" > /etc/resolv.conf
or
Do it manually by open the resolv.conf file and put in the DNS server you'd like use.
Mudit Kapil
  • 2,081
krt
  • 2,046
I think you should check new location.
Add your nameserver to/etc/resolvconf/resolv.conf.d/base.
Afterwards, run resolvconf -u.
Fabby
  • 35,017
If this is a desktop edition, you'd have to use network-manager to check your DNS servers. This can be done by clicking the network icon in the taskbar(bottom right) (if on wifi, it has a wifi symbol, if on ethernet it has a plug-like symbol) and selecting edit connections. Then double-click on your connection and proceed to IPv4 settings. Here, you can add the 8.8.8.8 DNS server. When adding DNS servers, however, I'd recommend you also change the dropdown box which says DHCP to DHCP for address only, so the DHCP doesn't supply you with a DNS server as well. (If you want to do this, you'll also need a router IP, which can be obtained by typing route -4 -n at commandline. It will give output like this:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         10.0.0.2        0.0.0.0         UG    6      0        0 home
10.0.0.0        0.0.0.0         255.0.0.0       U     0      0        0 home
127.0.0.0       0.0.0.0         255.0.0.0       U     0      0        0 lo
Simply use the Gateway value as your router.
If it's a server edition, you can follow @Kasper's instructions:
or manually edit the resolv.conf file and put in the dns server you'd like use.
Elder Geek
  • 36,752
Wilhelm Erasmus
  • 738
  • 24
The problem is probably because of the package resolvconf, see man page.
It is used to simplify adding and removing DNS servers from different sources. So the previous contents of /etc/resolv.conf is now managed by the the program resolvconf(8).
So, if you manage your network from /etc/network/interfaces, which is is good for servers, you just add dns-nameservers and dns-search for the right interface. See man page for resolveconf(8).
If it is from NM, I don't have a qlue, probably add to the static settings for the interfaces. If managed from DHCP, it should be set anyway.
Anders
  • 1,615
