I have configured my own DNS server and want to make it possible for everyone on the subnet to lookup each other.
How do I do that?
heemayl
  • 93,925
salim
  • 47
First, you need a DNS server. BIND Install BIND is example of widely used and standard server.
Below is an example for:
  • network named local.example.com
  • with IP addresses 192.168.0.0
  • and netmask 255.255.255.0 (24 bits)
For server:
  • named ns1
  • with IP number 192.168.0.1
And for 2 external DNS servers of:
  • 1.2.3.4
  • 1.2.3.5
Change those values accordingly to fit your network structure.
1. Install BIND
sudo apt-get install bind9
2. Add your local domain
In BINDs configuration file of /etc/named.conf.local add config for name queries (name to IP number):
zone "local.example.com" {
    type master;
    file "/etc/bind/db.local.example.com";
    allow-query { 192.168.0.0.0/24; 127.0.0.1; };
And for reverse queries (IP numbers to names):
zone "0.168.192.in-addr.arpa" {
    type master;
    file "/etc/bind/db.192.168.0";
    allow-query { 192.168.0.0/24; 127.0.0.1; };
Create two configuration files for your network. In /etc/bind/db.local.example.com, put:
$TTL    604800
@       IN      SOA     local.example.com. hostmaster.example.com. (
                        1503281         ; Serial
                         604800         ; Refresh
                          86400         ; Retry
                        2419200         ; Expire
                         604800 )       ; Negative Cache TTL
@       IN      NS      ns1.local.example.com.
ns1     IN      A       192.168.0.1
; Local computers
comp1   IN      A       192.168.0.101
comp2   IN      A       192.168.0.102
comp3   IN      A       192.168.0.103
In /etc/bind/db.192.168.0 put:
$TTL    604800
@       IN      SOA     v1.local.example.com. hostmaster.example.com. (
                        1503281         ; Serial
                         604800         ; Refresh
                          86400         ; Retry
                        2419200         ; Expire
@       IN      NS      ns1.
1       IN      PTR     ns1.local.example.com.
; Local computers
101      IN      PTR     comp1.local.example.com.
102      IN      PTR     comp2.local.example.com.
103      IN      PTR     comp3.local.example.com.
Note the Serial parameter: It may contain any number, and it should be changed every time you make changes to your config file. In this example it is constructed from date and unique number (YYMMDDN).
3. External resolutions
Your server needs to resolve other queries, configure external DNS servers in /etc/bind/named.conf.options as "forwarders":
 options {
    forwarders {
        1.2.3.4;
        1.2.3.5;
4. Load configuration
You can reload configuration by:
sudo service bind9 reload
Check /var/log/syslog if there is no errors loading your new configs.
5. Usage
You should now be able to query your DNS server from localhost and from clients of 192.168.0.0/24 network. They need to be configured to use this server (192.168.0.1) and this domainname (local.example.com) - eg. with DHCP configuration or statically in /etc/network/interfaces, like this:
auto eth0
iface eth0 inet static
        address 192.168.0.101
        gateway 192.168.0.1
        dns-nameservers 192.168.0.1
        dns-search local.example.com
To test your DNS on client machine (before switching permanently) you can try:
host comp1 192.168.0.1
madneon
  • 2,063
  • 14
  • 20
