31
Recently, I've been compelled to restart my computer a lot. When I boot, Ubuntu now starts scanning my hard drives for errors, but assures me that I can cancel if I want by pressing 'c'.
Why does Ubuntu do this? If it's necessary, why is it something I can cancel? If it's not necessary, why force me to do it? On what basis is the number of restarts decided?
jml
  • 1,035
A disc check is forced by the system every 30 restarts. If you skip the disc check it will do it the next time you restart (unless you manually remove forcecheck).
You can force this yourself by putting a file forcefsck in / by issuing a
touch /forcecheck
from the terminal.
It is not necessary to always do a check when it's prompted but should be done every now and then. You can cancel it if it is not the right moment for you at that time and let it do the file system check when it is more convenient.
You can also use tune2fs to alter this behaviour.
sudo tune2fs -c 60 /dev/sdXY
will set this to 60 restarts. You can also change this to a time period with -i:
sudo tune2fs -i 30d /dev/sdXY
for 30 days or 1m for 1 month or 10w for 10 weeks.
(replace /dev/sdXY by the device name for the partition like /dev/sda1. You can get this name by running sudo blkid or ls -lA /dev/disk/by-label if the partition is labelled)
sudo dumpe2fs /dev/sda1
will show loads and loads of information. Part of this includes:
Filesystem created:       Thu Feb 12 09:06:50 2009
Last mount time:          Fri Aug 26 07:19:34 2011
Last write time:          Fri Aug 26 07:19:34 2011
Mount count:              2
Maximum mount count:      25
Last checked:             Fri Aug 12 07:22:16 2011
Check interval:           15552000 (6 months)
Next check after:         Wed Feb  8 06:22:16 2012
Lincity
  • 25,749
Rinzwind
  • 309,379
These are routine file system checks, initiated every 30 reboots. The option to cancel it is there so that you are not detained from something critically important, however, it's recommended to let it run once in a while. I don't know on what basis the number of reboots was set, presumably, common sense. If it's too annoying, you can increase the number of reboots without checking partitions using the 'tune2fs' command.
Lekensteyn
  • 178,446
mikewhatever
  • 33,013
It is possible to completely disable the file system check on ext-filesystems using:
sudo tune2fs -c 0 /dev/sdXY
This might not be a good idea thou. The tune2fs manpage notes:
You should strongly consider the consequences of disabling mount-count-dependent checking entirely. Bad disk drives, cables, memory, and kernel bugs could all corrupt a filesystem without marking the filesystem dirty or in error. If you are using journaling on your filesystem, your filesystem will never be marked dirty, so it will not normally be checked. A filesystem error detected by the kernel will still force an fsck on the next reboot, but it may already be too late to prevent data loss at that point.
Thomas
  • 1,666
While mikewhatever and Rinzwind are right for ext-Filesystems, afaik, it doesn't happen if you choose to use reiserfs. I'm using it for 10 years without problems and can recommend it. No fsck any more.
I don't know for the other filesystems, popular on Linux.
user unknown
  • 6,892
