I'm following Ubuntu Wiki to install the drivers for hybrid-graphics in Ubuntu 14.04.2.
Here are the steps:
NVIDIA systems:
  1. Make sure that no other NVIDIA driver is installed (keep the nvidia-common package).
  2. Install nvidia-331.
  3. Reboot the system (restarting X won't be enough).
    NOTE: you can easily switch between GPUs from the Prime section of the nvidia-settings panel.
I'm not sure about step 1 - is it ok to just go to Additional Drivers and select nvidia-331 , will this uninstall other nvidia drivers if I have any ? And I guess this should install the driver (step 2) , or I have to do something explicitly like install from command line ?
Mudit Kapil
  • 2,081
Natasha
  • 177
Firstly,
sudo apt-get remove --purge nvidia*
Enable the Universe and Multiverse repositories - you need to do this to allow the bumblebee and nvidia packages respectively to be installed. Then:
sudo add-apt-repository ppa:bumblebee/stable
sudo apt-get update
sudo apt-get install bumblebee bumblebee-nvidia primus linux-headers-generic
sudo reboot
To run your application with the discrete NVIDIA card run in the terminal:
optirun [options] <application> [application-parameters]
Example:
optirun firefox
For a list of options for optirun run:
optirun --help
You can also use prime-select option e.g.
sudo prime-select nvidia
sudo prime-select intel
To check:
prime-select --query
JoKeR
  • 7,062
Please refer to this topic.
I've found there everything what I needed once.
dmwsky
