You can generate random art of any file with this little C program made by nirejan:
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#define XLIM 17
#define YLIM 9
#define ARSZ (XLIM * YLIM)
#define DEBUG 0
static uint16_t array[ARSZ];
const char symbols[] = {
' ', '.', 'o', '+',
'=', '*', 'B', 'O',
'X', '@', '%', '&',
'#', '/', '^', 'S', 'E'
void print_graph(void)
uint8_t i;
uint8_t j;
uint16_t temp;
printf("+--[ RandomArt ]--+\n");
for (i = 0; i < YLIM; i++) {
printf("|");
for (j = 0; j < XLIM; j++) {
temp = array[j + XLIM * i];
printf("%c", symbols[temp]);
printf("|\n");
printf("+-----------------+\n");
static char string[256];
static int ishex (char c)
if ((c >= '0' && c <= '9') ||
(c >= 'A' && c <= 'F') ||
(c >= 'a' && c <= 'f')) {
return 1;
return 0;
* The hexval function expects a hexadecimal character in the range
* [0-9], [A-F] or [a-f]. Passing any other character will result in
* undefined behaviour. Make sure you validate the character first.
static uint8_t hexval (char c)
if (c <= '9') {
return (c - '0');
} else if (c <= 'F') {
return (c - 'A' + 10);
} else if (c <= 'f') {
return (c - 'a' + 10);
return 0;
int convert_string(char *arg)
uint16_t i;
char c;
i = 0;
while (*arg && i < 255) {
c = *arg;
if (!ishex(c)) {
printf("Unrecognized character '%c'\n", c);
return 1;
arg++;
string[i] = hexval(c) << 4;
if (!*arg) {
printf("Odd number of characters\n");
return 1;
c = *arg;
if (!ishex(c)) {
return 1;
arg++;
string[i] |= hexval(c);
i++;
// Add the terminating null byte
string[i] = '\0';
return 0;
uint8_t new_position(uint8_t *pos, uint8_t direction)
uint8_t newpos;
uint8_t upd = 1;
int8_t x0;
int8_t y0;
int8_t x1;
int8_t y1;
x0 = *pos % XLIM;
y0 = *pos / XLIM;
#if DEBUG
printf("At position (%2d, %2d)... ", x0, y0);
#endif
switch (direction) {
case 0: // NW
#if DEBUG
printf("Moving NW... ");
#endif
x1 = x0 - 1;
y1 = y0 - 1;
break;
case 1: // NE
#if DEBUG
printf("Moving NE... ");
#endif
x1 = x0 + 1;
y1 = y0 - 1;
break;
case 2: // SW
#if DEBUG
printf("Moving SW... ");
#endif
x1 = x0 - 1;
y1 = y0 + 1;
break;
case 3: // SE
#if DEBUG
printf("Moving SE... ");
#endif
x1 = x0 + 1;
y1 = y0 + 1;
break;
default: // Should never happen
#if DEBUG
printf("INVALID DIRECTION %d!!!", direction);
#endif
x1 = x0;
y1 = y0;
break;
// Limit the range of x1 & y1
if (x1 < 0) {
x1 = 0;
} else if (x1 >= XLIM) {
x1 = XLIM - 1;
if (y1 < 0) {
y1 = 0;
} else if (y1 >= YLIM) {
y1 = YLIM - 1;
newpos = y1 * XLIM + x1;
#if DEBUG
printf("New position (%2d, %2d)... ", x1, y1);
#endif
if (newpos == *pos) {
#if DEBUG
printf("NO CHANGE");
#endif
upd = 0;
} else {
*pos = newpos;
#if DEBUG
printf("\n");
#endif
return upd;
void drunken_walk(void)
uint8_t pos;
uint8_t upd;
uint16_t idx;
uint8_t i;
uint8_t temp;
pos = 76;
for (idx = 0; string[idx]; idx++) {
temp = string[idx];
#if DEBUG
printf("Walking character index %d ('%02x')...\n", idx, temp);
#endif
for (i = 0; i < 4; i++) {
upd = new_position(&pos, temp & 3);
if (upd) {
array[pos]++;
temp >>= 2;
array[pos] = 16; // End
array[76] = 15; // Start
int main(int argc, char *argv[])
if (argc != 2) {
printf("Usage: bishop <hex string>\n");
return 1;
if (convert_string(argv[1])) {
printf("String conversion failed!\n");
return 1;
drunken_walk();
print_graph();
return 0;
To use it, follow these steps:
- Put the source code in a file:
- Open gedit or your favorite text editor.
- Paste the above source code.
- Save it as
bishop.c.
- Compile the code running
gcc bishop.c -o bishop.
View the random art of any file (where myfile is the file):
./bishop $(sha512sum myfile | cut -f1 -d ' ')
Create a custom script to view the random art of any file:
Create the local binaries folder if doesn't exists:
sudo mkdir -p /usr/local/bin
Create a file on that folder with the script:
sudo touch /usr/local/bin/randomart
Give permissions to the file:
sudo chmod 777 /usr/local/bin/randomart
Run gedit /usr/local/bin/randomart to edit the file and paste this on it:
#!/bin/bash
bishop $(sha512sum "$@" | cut -f1 -d ' ')
Save the file.
Copy the program that we built on the previous step to the local binaries folder:
sudo cp bishop /usr/local/bin/
Give run permission to the binary:
sudo chmod a+x /usr/local/bin/bishop
Use the newly-created program running randomart myfile where myfile is the file.
