I just need to run a shell script when an internet connection is available. Is it possible to watch the internet connection availability through shell scripting?
ping google.com is the easy command to get it working. But how can I watch it?
If watching means looking at transfer speeds, I have two solutions.
ifstat -S
sudo iftop
You could do something like this
#!/bin/bash
while [ 1 ]; do
TEST=$(nmcli -f STATE dev status | awk '/connected/ {print 1}')
if [ $TEST ]; then
# place whatever you wanna do here if connection is available
fi
sleep 0.25
done
nmcli has command dev status that shows the status of network interfaces. So, we check only the status column of the output with the -f STATUS format flag. If we have connection, regardless if that's ethernet or wifi, we set TEST variable to 1 , meaning true. Next is if . . then . . .fi statement, which actually does the job.
