Is there a way to get Docky ton act like Gnome-Do? I installed just the docky package. I would like it to be able to search for other things that are not in the dock. Is this possible or would it just be easier to install Gnome-Do separate.
Lucid's version of Gnome-Do still has the Docky interface available, and it will act like Gnome-Do when you push the keyboard shortcut for Gnome-Do. You shouldn't even need to have Docky installed separately. The version in Maverick removed the Docky interface. (Both are numbered 0.8.3.1 in the about dialog, however.)
Once you have a version of Gnome-Do without Docky removed (see below), the next thing is to run Gnome-Do. If Gnome-Do doesn't pop up when you run it, summon it with Windows Key + Space. Click the downward-pointing triangle on the top right corner of Gnome-Do and click Preferences. Click on the Appearance tab and select the Docky theme in the drop-down at the top of the tab. You can then configure Gnome-Do just as you would configure Docky.
The versions of the gnome-do packages after 0.8.3.1+dfsg-1ubuntu1 (0.8.3.1+dfsg-2 and 0.8.3.1+dfsg-2ubuntu1) removed the Docky theme. Maverick is also missing the gnome-do-docklets package.
You could download gnome-do and gnome-do-docklets from the Ubuntu Lucid repositories (you could probably still install Maverick's version of gnome-do-plugins with it). It looks like the only fix you'd miss out on is one for crashes caused by GNOME Keyring. I'm not experienced enough to guarantee this will work right, but I'd do it on my own computer. I have at least checked to ensure there aren't any dependency issues.
A surer, but more difficult, approach, would be to build the latest release of gnome-do but reverse the effects of the patch debian/patches/03_disable_docky.dpatch.
- 570
For now, you'll need to install them separately and use them without integration; Docky was split from Do a while ago. The next Do release will likely reintroduce Docky integration.
- 9,910
