I can't make my laptop's onboard bluetooth to work correctly and permanently without disabling xHCI from BIOS.
Bluetooth is always shown as disabled after booting the computer. When trying to enable it from the bluetooth settings (click on bluetooth icon-> select "bluetooth settings") I get this from dmesg:
[  948.641625] usb 1-4: USB disconnect, device number 2
[  948.912013] usb 1-4: new full-speed USB device number 5 using xhci_hcd
[  949.041299] usb 1-4: New USB device found, idVendor=8087, idProduct=07dc
[  949.041305] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  949.055380] Bluetooth: hci0: read Intel version: 370710018002030d00
[  949.057370] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.80.2.3.d.bseq
[  949.233672] Bluetooth: hci0: Intel Bluetooth firmware patch completed and activated
I can see the bluetooth "switch" become on and back off immediately, at the same time the above dmseg messages appear.
My system:
  • Laptop Asus UX301LA
  • wireless and bluetooth interface is based on Intel 7260 chipset.
  • Ubuntu 14.10 with latest updates
  • (kernel 3.16.0-31-generic at the moment, and regularly updated)
What other tried and discovered
Here is a very complete thread which documents a long investigation by the author, and everything that has been tried so far by him.
What is causing my Intel 7260 bluetooth device to disconnect when I unblock it with rfkill?
And this is a bug report on the subject:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1209124
What I have already tried:
Following comment #7 I can get bluetooth to temporarily work along with xHCI. But this is VERY hacky and does not survives reboots, nor resists basic use of the laptop (like switching wifi on and off).
I have tried setting the option asus_nb_wmi wapf=X to 0,1,2,3, or 4 (in the file /etc/modprobe.d/asus_nb_wmi.conf) seeing no change in the behavior.
I also tried blacklisting btusb, since it might be loading too early (as suggested by Jeremy31: echo "blacklist btusb" | sudo tee /etc/modprobe.d/btusb.conf). You can see here a snip from my dmesg.
  • Up to second 90, the computer had just booted up. Bluetooth settings shows that bluetooth is disabled.
  • At second 90, I click on the "switch" to enable bluetooth. The switch stays on, but bluetooth is obviously still not working (because we blacklisted it).
  • At second 99, I click on the switch to disable it.
  • Then on seconds 111, 118, 123 and 126, I repeat the last 2 steps, and get the same result.
  • On second 145 I ran sudo modprobe btusb to load btusb module again.
  • Finally, on second 157 I click on the switch again to enable bluetooth, but this time, it comes immediately back off.
So....
There could be a fix already released in newer versions of the kernel, which I don't know how to install nor try. If so, I am more than happy to try.
I would like to find a way to solve this problem definitely, in a way that survives reboots, and allows me to enable and disable bluetooth with the keyboard Fn buttons.
Thank you.
chronos00
  • 771
I solved this problem on my Asus Zenbook UX301L by replacing the Intel 7260 wifi/BT adaptor with an Intel 7265 wifi/BT adaptor. The problem immediately vanished. The only problem was getting the back off the UX301L. Not easy.
user594707
  • 1,289
I had this error before but it was solved with some configurations in bios if you can just have a try!
In USB configuration Enable
Leagacy USB support
USB 3.0 support
XHCI Hand-off
EHCI Hand-off
and in SOUTH or NORTH bridge there will be option chipset go into it and.
make XHCI mode Enable
make USB2 Link Power Management Disbale
make USB 2.0 (EHCI) Support Disable
Tohid Tamboli
  • 821
