I'm using Ubuntu 14.04 from wubi application with Windows 7 as partition. I was using ubuntu for some time. After that it freezes for some time and I shut it down by long press on the power button. when I start ubuntu again it doesn't boot and it gives me
Minimal Bash-Line editing is supported. for the first word. TAB lists possible command completions. Anywhere else TAB lists possible device or file completions grub->
but I can still sing windows. Can anyone help me to reboot it again or at least to restore my files from my home directory ?
You should have a Ubuntu folder inside Windows. Maybe you can use a USB stick with ubuntu to boot your system so you can see the files inside that folder. IMHO you should install ubuntu properlly because wubi is not a good solution.
See this link Installation from USB stick
Or you can try this: How to restore the wubi ubuntu bootloader
lapisdecor
  • 1,647
  • 19
  • 39
