When I try to install it, the following result comes up:
Reading package lists... Done
Building dependency tree
 mono-complete : Depends: mono-devel (= 3.12.1-0xamarin1) but it is not going to be installed
                 Depends: mono-4.0-service (= 3.12.1-0xamarin1) but it is not going to be installed
                 Depends: libmono-cil-dev (= 3.12.1-0xamarin1) but it is not going to be installed
xangua
  • 7,277
For the benefit of others, here is one scenario where this problem occurred for me: using the latest Jenkins docker repository, which is based on Debian 8 "jessie".
I ran the normal mono install instructions, including
apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
echo "deb http://download.mono-project.com/repo/debian wheezy main" | tee /etc/apt/sources.list.d/mono-xamarin.list
Then the apt-get install -y mono-devel was failing with unmet dependencies.
I tried reloading the docker image and running the install without the two commands above. Suddenly it worked.
Apparently the standard third party repository for mono isn't needed with the latest (as of March 30 2016) jenkins image.
Parto
  • 15,647
sfuqua
  • 101
