119
I want to change an icon of a specific theme. Where do themes save their icons?
Ingo
  • 6,348
5 Answers5
149
Globally: /usr/share/icons/ or in your home folder : ~/.local/share/icons
skoal
  • 1,570
30
There are several places: (in bracets some examples)
  • /usr/share/pixmaps/ ( chromium-browser.png display-im6.q16.xpm firefox.png flash-player-properties.png gimp.xpm gvim.svg texstudio.xpm )
  • /usr/share/app-install/icons/ ( adobeflashplugin.png julia.svg texmaker.png thunderbird.png vim.svg vlc.png wine.svg grace.svg)
  • ~/.local/share/icons/ ( soffice.png java-lang-thread.png org-jabref-jabrefmain.png) one of the places where Ubuntu searches for icons, if you use relative path
  • /usr/share/icons/... and subfolders ( matlab.png .../hicolor/scalable/apps/chromium-browser.svg .../hicolor/scalable/apps/geany.svg .../hicolor/scalable/apps/okular.svgz .../default.kde4/48x48/apps/acroread.png)
  • /usr/share/... just subfolders ( .../vlc/vlc.ico .../gimp/2.0/images/gimp-logo.png ) but this one is more for icons used in the program that the logo of the program
  • /snap/... just subfolders ( .../inkscape/3080/meta/gui/inkscape.svg .../languagetool/10/snap/gui/icon.png )
  • ~/.icons related to freedesktop.org (source1, source2 )
Most of the folders are already announced here, all sources I used:
JoKalliauer
  • 1,674
  • 20
  • 27
27
/usr/share/icons/ typically contains pre-installed themes (shared by all users) ~/.icons/ typically contains folders with the themes installed by the user.
Also, many applications have their icons in /usr/share/pixmaps/ or in the folder with the same name as the application under /usr/share/...
v2r
  • 9,707
Vadim
  • 1,388
To add to some of the answers here:
The freedesktop.org standard requires programs to look for icons in multiple folders in this order:
  1. $HOME/.icons (for backwards compatibility)
  2. $XDG_DATA_DIRS/icons, which typically just means ~/.local/share/icons.
  3. /usr/share/pixmaps
So if you want a custom icon, your best bet is to find the icon name in /usr/share/pixmaps, and then create an image with that same file name in ~/.local/share/icons.
As a supplementary for the accepted answer: If you don't find the ~/.icons directory, there may be a ~/.local/share/icons directory instead (PS: My distro is Ubuntu 16.10).
