From man ln:
By default, each destination (name of new link) should not already exist.
As you already have a directory named html, the link will be created inside /var/www/html having the name of the target i.e. project.
If you want to have a symlink /var/www/html pointing to /home/user/project then you should not have the directory html present beforehand. So, you should only have /var/www and then running the following will create the desired symlink (don't do this unless you are sure):
ln -s /home/user/project /var/www/html
Note: if you use a trailing slash (like in ln -s /home/user/project /var/www/html/) you will get an error: ln: target '/var/www/html' is not a directory: No such file or directory.
Here is an example:
$ pwd
/home/user/test/askubuntu
$ ls -l
total 4
drwxrwxr-x 2 user user 4096 Mar 25 00:16 foo
$ ln -s /home/user/test/bar /home/user/test/askubuntu/foo
$ ls -l
total 4
drwxrwxr-x 2 user user 4096 Mar 25 00:17 foo
$ cd foo/
$ ls -l
total 0
lrwxrwxrwx 1 user user 25 Mar 25 00:17 bar -> /home/user/test/bar
$ cd ..
$ rm -r foo/
$ ls -l
total 0
$ ls -l
total 0
lrwxrwxrwx 1 user user 25 Mar 25 00:18 foo -> /home/user/test/bar
And yes, you can create symlinks of hidden files.
