Running Ubuntu 11.04. Got a bamboo Touch&Pen CTH-460 and it works out of the box. The pen response works great but the finger response is horrible. Is there a way to disable the finger response and only have the pen work? The tablet clearly differentiates between the two, so there should be a way to disable one. any thoughts?
Found my solution.
Edit /usr/share/X11/xorg.conf.d/50-wacom.conf and add "Option "Touch" "off"" to each group. Works like a charm.
    - 14,515
    - 71
You could use the command line utility xinput. First use xinput list to find your device id:
user@ubuntu:~$ xinput list
⎡ Virtual core pointer                      id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ Logitech USB Trackball                    id=10   [slave  pointer  (2)]
⎜   ↳ Wacom ISDv4 E3 Finger                     id=11   [slave  pointer  (2)]
⎜   ↳ Wacom ISDv4 E3 Pen                        id=12   [slave  pointer  (2)]
⎜   ↳ SynPS/2 Synaptics TouchPad                id=15   [slave  pointer  (2)]
⎣ Virtual core keyboard                     id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ Power Button                              id=6    [slave  keyboard (3)]
    ↳ Video Bus                                 id=7    [slave  keyboard (3)]
    ↳ Video Bus                                 id=8    [slave  keyboard (3)]
    ↳ Power Button                              id=9    [slave  keyboard (3)]
    ↳ HP Webcam                                 id=13   [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=14   [slave  keyboard (3)]
    ↳ HP WMI hotkeys                            id=16   [slave  keyboard (3)]
So in my case, the touch part has device id equal to 11. Next, you set the device enabled property use xinput set-prop, like this:
user@ubuntu:~$ xinput set-prop 11 "Device Enabled" "0"
You can enable it again with:
user@ubuntu:~$ xinput set-prop 11 "Device Enabled" "1"
You'll have to do this every time you restart your computer. Also, the device id may change between boots.
    - 9,173
http://ubuntuforums.org/showpost.php?p=9496609&postcount=1
There you'll find a script to disable/enable the touch AND a patch to fix the touch problem. Worked perfectly with mine.
    - 11
You can also use xsetwacom, which I think is a proxy for xinput, but for wacom/touch devices only. The id numbers in xsetwacom --list devices match up to xinput list.
Well, here's how to use xsetwacom:
this@this:~$ xinput list
⎜   ↳ Wacom ISDv4 E6 Pen stylus                 id=10   [slave  pointer  (2)]
⎜   ↳ SynPS/2 Synaptics TouchPad                id=13   [slave  pointer  (2)]
⎜   ↳ Wacom ISDv4 E6 Pen eraser                 id=15   [slave  pointer  (2)]
⎜   ↳ TPPS/2 IBM TrackPoint                     id=16   [slave  pointer  (2)]
⎜   ↳ Wacom ISDv4 E6 Finger touch               id=11   [slave  pointer  (2)]
    ↳ Sleep Button                              id=8    [slave  keyboard (3)]
    ↳ Integrated Camera                         id=9    [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=12   [slave  keyboard (3)]
    ↳ ThinkPad Extra Buttons                    id=14   [slave  keyboard (3)]
this@this:~$ xsetwacom --list devices
Wacom ISDv4 E6 Pen stylus           id: 10  type: STYLUS
Wacom ISDv4 E6 Pen eraser           id: 15  type: ERASER
Wacom ISDv4 E6 Finger touch         id: 11  type: TOUCH
this@this:~$ xsetwacom set 11 Touch "off"
this@this:~$
    - 5,891
