Received my Bq Ubuntu phone yesterday, finally got around to playing with it today, and one of the first things I've noticed is that it doesn't seem to play any of my mp3's that are on my sd card.
The music app detects all the songs fine, and the play bar progresses (for a lot of the songs, some it doesn't offer the choice to play), but no sound comes out, either via speakers or headphones.
Now looking at some ubuntu docs, mp3's are restricted by default, is that still the case on the phone OS?
(Apologies if not quite the right place to ask, I'd ask on the sub-reddit, but all tech support (which this could be classed as?) needs to come from here)
nik90
  • 12,959
Psytronic
  • 143
Did you try to check if you was affected by this volume muted bug ?
It happens when you play the game PathWind or Machines vs Machines, and mute the in-game volume. It will also mute the system volume whitch is a bug. This bug is now tracked at the link above.
Steps to fix it:
Simply launch the game PathWind on the phone, and check the setting of the game, in sound, and unmute. Should fix it.
Other known reason
If you are on the devel-proposed channel, you might be affected by this bug.
cm-t
  • 539
