This is probably a real noob question...
I would like to understand what the "updates" alerts I get when logging onto my Lubuntu box actually mean.
When I read:
35 packages can be updated.
22 updates are security updates.
I understand that there are 22 security updates and 13 "regular" updates, for a global count of 35 updates.
As I want to run only security updates, I run:
sudo unattended-upgrade
But after that, I do not get any update notification any longer until the next updates cycle, so all the packages, security and not security, seem to be updated.
This seems also confirmed with:
sudo /usr/lib/update-notifier/update-motd-updates-available
Which replies with a blank output.
Someone can explain? Thanks!
Mat
  • 61
  1. The security updates are updates that fixes security bugs that can compromise the system, the rest are updates of improvement that fixes non-critic bugs or adds new features to a program. However, its recommended to install all updates.
  2. When do you see this:
    Yes, you think correctly, there is a total of 35 updates, 22 of which are security updates, and the rest are normal updates.
  3. unattended-upgrade upgrades all packages, in the man page says this:
    automatic installation of security (and other) upgrades
    You can test this running man unattended-upgrade
0x2b3bfa0
  • 9,110
  • 38
  • 55
Firstly, to quote the man page: "unattended-upgrade - automatic installation of security (and other) upgrades"
and other - it's going to do the lot...
The difference is that security upgrades are deemed important for security - so things like vulnerabilities in programs - & the others are just upgrades to a program with no bearing on security.
The point being, security ones should be done rapidly, the others aren't as important - but, if you avoid them, your system will become less up-to-date & eventually something will probably break. If you carry on as you are, you'll be fine.
