I have recently installed plexmediaserver 64-bit from the plex site on my Kubuntu 15.04 laptop and am unable to start. I believe it is in the change from how init scripts work?
If you look at the guide for Plex it says to execute /etc/init.d/plexmediaserver start once you have installed it for the first time.
It appears that /etc/init.d/plexmediaserver is an invalid symlink or something?
Not sure where to go to help troubleshoot this...
jjesse
  • 1,115
Had the same issue on Ubuntu 15.04
Resolved it by creating a new file: /etc/systemd/system/plexmediaserver.service
Afterwards, pasted the following:
[Unit]
Description=Plex Media Server for Linux
After=network.target
[Service]
Environment="PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR=/var/lib/plexmediaserver/Library/Application Support"
Environment=PLEX_MEDIA_SERVER_HOME=/usr/lib/plexmediaserver
Environment=PLEX_MEDIA_SERVER_MAX_PLUGIN_PROCS=6
Environment=PLEX_MEDIA_SERVER_TMPDIR=/tmp
Environment=LD_LIBRARY_PATH=/usr/lib/plexmediaserver
Environment=LC_ALL=en_US.UTF-8
Environment=LANG=en_US.UTF-8
ExecStartPre=/bin/sh -c '/usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}"'
ExecStart=/bin/sh -c '/usr/lib/plexmediaserver/Plex\ Media\ Server'
Type=simple
User=plex
Group=plex
Restart=on-failure
RestartSec=5
StartLimitInterval=60s
StartLimitBurst=3
[Install]
WantedBy=multi-user.target
Then run, sudo service plexmediaserver start
Plex should start normally and you should be able to access it through: http://127.0.0.1:32400/web
Source
A.B.
  • 92,125
The above script was already on my system and it still was not working. Upgrading to 0.9.12.4.1192 fixed all issues with systemd.
Drew
  • 370
