When I try to install Ubuntu, after I select install, the monitor displays this:
Booting 'Install Ubuntu'
(hd0,1)
Filesystem type is ntfs, partition type 0x7
[Linux-bzImage, setup=0x4200, size=0x583c58]
[Linux-initrd @ 0x7ec26000, 0x13c9603 bytes]
Previously I tried to install with two monitors (a HDMI TV and a VGA monitor), with the VGA monitor being the one I currently use. When I did this, the HDMI TV worked, with the VGA monitor displaying the same as it is now. FYI: No, I don't have the HDMI TV to use
I also have a NVIDIA GTX 750 Ti as a graphics card, which plugs into the monitor with a DVI adapter
UPDATE: I plugged the VGA cable into the motherboard so I can install Ubuntu, but I would still like to be able to use my (fairly expensive) GPU
After some frustration I have fixed my problem. All I needed to do was install an older driver (340) because the newer one had a bug. For those who are also in the same position I was in, I used this guide to install the driver.
