As of now, I am able to run Ubuntu Unity through VirtualBox. Now, I want to install Ubuntu to a partition, which I have already created AND formatted. However, in VirtualBox, when I click 'install Ubuntu', at step 4/7, the block which should list partitions (with header 'Device Type Mount point etc.' is completely blank.
I have no idea what I have to do next. Why is nothing listed there? If I simply click install now, it says
No root file system is defined. Please correct this from the partitioning menu.
I want to, but I can't... has anyone experienced this before? I run Linux through a LiveUSB, the Linux version is 64bit. No problems when booting in VirtualBox, everything is possible inside it.
If you need more information, I'll gladly give it to you :D
Byte Commander
  • 110,243
