On my local network, I can VNC-over-an-ssh-tunnel quite easily. I wish to do the same from abroad.
The server is set up to accept WAN-side ssh connections, and this works reliably. The problem is, when abroad I cannot start a successful VNC session over the ssh tunnel. A similar tunneling setup is used when I do the same on my LAN (which works perfect).
So "from over there," I can connect SSH, but when I try to connect VNC to 127.0.0.1, I get on UltraVNC: Connection failed - End of stream Possible causes - Another user is already listening on this ID - Bad connection ...with whatever ports I may use.
Luckily TightVNC provides some level of logging. A failed connection is recorded as such:
[  512/ 1904] 2015-03-22 10:33:34:617 : Initialization of socket stream and input/output gates...
[  512/ 1904] 2015-03-22 10:33:34:617 : Connection is established
[  512/ 1904] 2015-03-22 10:33:34:617 - Protocol stage is "Handshake".
[  512/ 1904] 2015-03-22 10:33:34:647 - onDisconnect: Connection has been gracefully closed
[  512/ 2060] 2015-03-22 10:33:35:719 - Process focus restoration in the RfbKeySym class
[  512/ 2060] 2015-03-22 10:33:35:719 - Process focus loss in the RfbKeySym class
[  512/ 2060] 2015-03-22 10:33:35:829 - Process focus restoration in the RfbKeySym class
And a successful one looks like this (from my LAN):
[ 7536/ 2900] 2015-03-22 11:22:28:892 : Initialization of socket stream and input/output gates...
[ 7536/ 2900] 2015-03-22 11:22:28:892 : Connection is established
[ 7536/ 2900] 2015-03-22 11:22:28:892 - Protocol stage is "Handshake".
[ 7536/ 8032] 2015-03-22 11:22:28:946   client rect: 0, 0; 124, 31
[ 7536/ 8032] 2015-03-22 11:22:28:946   Desktop-window. (x, y): (0, 29); (w, h): (124, 2)
[ 7536/ 2900] 2015-03-22 11:22:29:040 - Server sent protocol version: RFB 003.008
[ 7536/ 2900] 2015-03-22 11:22:29:040 - Send to server protocol version: RFB 003.008
After weeks of hair-pulling, different client attempts and trying whichever port-forwarding configuration I could think of (on either side's routers), I finally made a breakthrough.
I set up a second ssh tunnel in PuTTY - Dynamic at port 1080 (D1080). I then used a VNC client that allows a proxy connection, RealVNC VNC-Viewer, and pointed it at localhost port 1080 (type SOCKS 5).
THIS. WORKS. I am now sure my VNC session is secured, but only if I go through a local SOCKS proxy when I am abroad. The down side is I can not use my favorite client UltraVNC Viewer.
Also, I do not understand what is going on; I am looking for an explanation. Why doesn't the simple L5900 tunnel do the job from then WAN, when it does within the LAN?
Tfb9
  • 681
The problem here is the SSH tunnel setup in PuTTY.
Based on a web tutorial, I set up my 5900 SHH tunnel with the LAN IP adress of the server 192.168.1.110, so it looked like L5900 192.168.1.110:5900 in PuTTY. Target host was also 192.168.1.110. As we know this worked fine.
Then I configured my SSH session with PuTTY for use abroad. Shame on me, I used the WAN IP in both the target host and the tunnel. I now realize that when it received packets destined to port 5900, the OpenSSH server did as instructed - it forwarded them to my NAT router (or tried to, anyway, as the pointer was to a WAN address).
The sure way to configure PuTTY is to always use the LAN IP for the 5900 tunnel. Better yet, as in my case the VNC server is on the same machine as the OpenSSH server, just use localhost for the tunnel, as in L5900 localhost:5900.
Tfb9
  • 681
