I try to copy from the descriptions and paste the code into the terminal but it doesn't work. Even the rightmouse click does not work.
Ctrl+V or Ctrl+Shift+V does not work even the right mouse click does not work.
What can I do pls?
UPDATE: I found this answer (but is not for ubuntu 14.04): https://askubuntu.com/a/113308/390077
Marco
  • 63
Select what you want to copy, then use the middle button of your mouse to paste. If you don't have a middle button, try pressing both mouse buttons at once.
In any case, CtrlV isn't supposed to work. The shortcut for pasting into a terminal after having copied with CtrlC is ShiftInsert
terdon
  • 104,119
In terminal, I select the text by dragging with the left mouse button, press the right mouse button and select copy from the pop-up menu.
To paste, press the right mouse button and select paste from the pop-up menu.
LDC3
  • 546
I found if you install Gnome terminal you can rightmouse click!
Marco
  • 63
