I am new to zenity and I am trying to make a simple script for loading a file using zenity --file-selection and the wc command to get the word count of that file. I have successfully made a form which can be used to browse the file but I am unable to get any output. Can you please tell me where I am making the mistake?
My current script is:
#creates a box
if zenity --entry \
--title="Word count" \
--text="Enter file location" \
--entry-text "File path"
  then
#Zenity file selection code for browsing and selecting files
FILE=`zenity --file-selection --title="Select a File"`
case $? in
         0)
                echo "\"$FILE\" selected.";;
         1)
                echo "No file selected.";;
        -1)
                echo "An unexpected error has occurred.";;
esac
# To show the location in the text box
if zenity --entry \
--entry-text "$FILE"
then
#word counting code
word_count='wc $FILE'
zenity --info --title="Word Counted" --text="Counted words $word_count"
fi
fi
terdon
  • 104,119
Eka
  • 3,007
In order to save the output of a command in a variable, you must enclose the command in backtics (`command`) or, better, in $() ($(command)). You are using single quotes which means that you are saving the string wc $FILE and not actually running wc:
$ foo='wc /etc/fstab' ## WRONG
$ echo $foo
wc /etc/fstab
$ foo=`wc /etc/fstab`  ## RIGHT
$ echo $foo
23 96 994 /etc/fstab
$ foo=$(wc /etc/fstab)   ## RIGHT
$ echo $foo
In addition, in order to get only the words and not the number of characters and lines, use the -w option:
$ foo=$(wc -w /etc/fstab)
$ echo $foo
96 /etc/fstab
Finally, to get the number alone, with no file name, you can use:
$ foo $(wc -w /etc/fstab | cut -d ' ' -f 1 )
$ echo $foo
96
terdon
  • 104,119
I think that the correct code may be this:
#!/bin/bash
function count() {
  word_count=$(wc -w < "$FILE")
function choose() {
  FILE="$(zenity --file-selection --title='Select a File')"
  case $? in
           0)
                  count;;
           1)
                  zenity --question \
                         --title="Word counter" \
                         --text="No file selected. Do you want to select one?" \
                         && choose || exit;;
          -1)
                  echo "An unexpected error has occurred."; exit;;
  esac
choose
0x2b3bfa0
  • 9,110
  • 38
  • 55
