Usually, it is the other way around...so this might be the first from what I researched.
lets say i log on to my server venus as willc86. When I su root, it lets me in. however, lets say I ssh venus -l root, it wont let me. access denied. if I ssh venus -l willc86 it works, but I have to su root in order to switch
is this a ssh problem?
user2805313
  • 337
As bodhi.zazen mentions, root log in from ssh might be disabled.
Honestly, this is not a bad thing. You might want to consider getting used to having to "su -" to root if you have to (or sudo -i if you use it).
Try the following to check,
grep PermitRootLogin /etc/ssh/sshd_config
If you see the following come by, root login is disabled.
PermitRootLogin no
Or if the output is the following, root login cannot be done with passwords:
PermitRootLogin without-password
To change this setting, use your favorite text editor (vi/nano) and change no to "yes"
Again, consider getting used to working with "su -/sudo" when needed before changing this.
EDIT/Sidenote: Also, this will only work if you actually set a password for the root user.
muru
  • 207,228
Sinn3d
  • 189
