System info:
Linux ravi-Inspiron-N5010 3.13.0-46-generic #79-Ubuntu SMP Tue Mar 10
20:08:14 UTC 2015 i686 i686 i686 GNU/Linux
Using Ubuntu 14.04.2 LTS.
I am struggling to run tftp localhost.
Tried:
root@ravi-Inspiron-N5010:/home/ravi/Desktop# service tftpd-hpa restart
tftpd-hpa stop/waiting
tftpd-hpa start/running
root@ravi-Inspiron-N5010:/home/ravi/Desktop# service tftpd-hpa status
Now I get error:
root@ravi-Inspiron-N5010:/home/ravi/Desktop# tftp 127.0.0.1
tftp> put test
Error code 2: Access violation
tftp>
permission of the file I am trying to put is :
root@ravi-Inspiron-N5010:/home/ravi/Desktop# ls -ld test
-rwxrwxrwx 1 ravi ravi 0 Mar 21 20:09 test
Permission of the /tftpboot folder:
root@ravi-Inspiron-N5010:/# ls -ld  tftpboot/
drwxrwxrwx 2 nobody root 4096 Mar 15 15:34 tftpboot/
Additional Information
root@ravi-Inspiron-N5010:/home/ravi/Desktop# nano /etc/xinetd.d/tftp
service tftp
   protocol = udp
   port = 69
   socket_type = dgram
   wait = yes
   user = nobody
   server = /usr/sbin/in.tftpd
   server_args = /tftpboot -s
   disable = no
Please help me resolve this issue.
Zanna
  • 72,312
8 Answers8
The file you want to put via tftp must exist in the destination directory, and have permissions allowing it to be overwritten. For your instance, test must exist in /tftpboot.
You can see the reason in the tftp man page BUGS section.
I'm struggling to solve how to put a new file via tftp, but still don't know how.
Zanna
  • 72,312
Check syslog and you will see that :
 tftpd: serving file from /srv/tftp
Basically there is a bug and you will need in your case to move all files from the folder /tftpboot to /srv/tftp (make the folder /srv/tftp if doens't exist) and make sure you give 777 permissions and to all file inside, restart xinetd and it will works!
Zanna
  • 72,312
This could be because 14.04 has a tftp server setting in /etc/inetd.conf:
#BOOT: TFTP service is provided primarily for booting.  Most sites
#       run this only on machines acting as "boot servers."
tftp    dgram  udp wait    nobody  /usr/sbin/tcpd  /usr/sbin/in.tftpd /srv/tftp
you can comment out this line and try again.
I got this from here: http://www.beer.org/blog/tftpd-and-xinetd-on-ubuntu.html
Jakuje
  • 6,793
hashtpaa
  • 123
As leondgarse mention, you cannot upload new files directly with your settings. But you can add "-c" to server_args, like:
service tftp
   protocol = udp
   port = 69
   socket_type = dgram
   wait = yes
   user = nobody
   server_args = -c -s /tftpboot
   disable = no
For detail, you can see man page of "in.tftpd":
   --create, -c
          Allow new files to be created.  By default, tftpd will only allow upload of files that already exist.  Files are created with default permissions allow‐
          ing anyone to read or write them, unless the --permissive or --umask options are specified.
alfred
  • 603
In my case it (Debian 9.9) I resolve it by editing /etc/inetd.conf and modifying the line :
by
tftp dgram udp wait nobody /usr/sbin/tcpd /usr/sbin/in.tftpd /tftpboot
The file "/etc/xinetd.d/tftp" was not reading.
Not sure if this is something with the design of TFTP but when doing a put it does not let you create a file.
Solution:
Create the file before hand and give 777 rights. Run transfer again and it should work.
michael
Troubleshooting TFTPD Server on Ubuntu 14.0.4 by Dayanand Ambawade
Step-1: Edit /etc/inetd.conf
tftp dgram udp wait nobody /usr/sbin/tcpd /usr/sbin/in.tftpd /srv/tftpboot
Step-2: Write script for tftpd
sudo nano /etc/xinetd.d/tftp
service tftp
   protocol = udp
   port = 69
   socket_type = dgram
   wait = yes
   user = nobody
   server_args = /srv/tftpboot -s
   disable = no
Step-3: Create Directory and set the permissions
sudo mkdir /srv/tftpboot
sudo echo "Test TFTP Server" > /srv/tftpboot/test.txt
sudo chmod 777 -R /srv/tftpboot
sudo chown -R nobody.root /srv/tftpboot
Step-4: Start service
sudo service xinetd restart
sudo service inetutils-inetd restart
Step-5: Test Server
echo "get test.txt" | tftp 127.0.0.1
cat test.txt
Test TFTP Server
Hopefully this will solve the problem. Regards
Please check the files mode bits.
In my case, the tftp root directory is /opt/tftpboot/
Using ls -l command, I could see the file mode was 600, so when I try to access tftp to get this file with anonymous, it reports an access violation.
This may be the cause of this error. But there may be another reason for it.
Zanna
  • 72,312
