I am on Ubuntu 14.04. I want to install two packages: pantheon-shell and elementary-tweaks but getting following error:
$ sudo apt-get install pantheon-shell
Reading package lists... Done
Building dependency tree
 pantheon-shell : Depends: slingshot-launcher but it is not going to be installed
              Recommends: gala but it is not going to be installed
$ sudo apt-get install elementary-tweaks
 elementary-tweaks : Depends: gala but it is not going to be installed
I tried this, didnt help:
$ sudo apt-get -f install
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Zanna
  • 72,312
Alex Jones
  • 8,192
Try the following, in the shown order
sudo apt-get autoclean && apt-get clean
sudo aptitude update && sudo aptitude -y upgrade
sudo aptitude install <package>
s1mmel
  • 2,124
I guess the repos have the same packages but with different versions?
I think you need APT Pinning for that, to tell apt which repo you prefer to install from.
ppa:elementary-os/testing
ppa:elementary-os/daily
This might be your problem. You need to give these repos prio's.
s1mmel
  • 2,124
