I am finding it impossible to completely remove plex from my Ubuntu system, i get the following error:
davewold@ubuntuhome:~$ sudo aptitude purge plexmediaserver
[sudo] password for davewold:
no talloc stackframe at ../source3/param/loadparm.c:4864, leaking memory
Ignoring unknown parameter "announce version"
The following packages will be REMOVED:
  libavahi-core7{u} libavahi-gobject0{u} plexmediaserver{p}
0 packages upgraded, 0 newly installed, 3 to remove and 0 not upgraded.
Need to get 0 B of archives. After unpacking 409 kB will be freed.
Do you want to continue? [Y/n/?] y
(Reading database ... 204286 files and directories currently installed.)
Removing libavahi-core7:amd64 (0.6.31-4ubuntu1) ...
Removing libavahi-gobject0:amd64 (0.6.31-4ubuntu1) ...
Processing triggers for libc-bin (2.19-0ubuntu6.6) ...
(Reading database ... 204272 files and directories currently installed.)
Removing plexmediaserver (0.9.11.7.803-87d0708-debian) ...
Plex Media Server is not running (no process found)...
update-rc.d: /etc/init.d/plexmediaserver exists during rc.d purge (use -f to force)
dpkg: error processing package plexmediaserver (--purge):
 subprocess installed pre-removal script returned error exit status 1
 plexmediaserver
A package failed to install.  Trying to recover:
heemayl
  • 93,925
Try to force the removal with sudo aptitude -f purge plexmediaserver If it doesn't work, try these commands:
sudo rm -f /etc/init.d/plexmediaserver
sudo dpkg --purge --force-all plexmediaserver
0x2b3bfa0
  • 9,110
  • 38
  • 55
Shot in the dark, but it helped me sometimes.
Reinstall the package, then try sudo apt-get --purge remove <package>.
Also make sure no process is running, related to this package.
If this doesn't work then do it the hard way..
mv /var/lib/dpkg/info/<package>.* /tmp/
dpkg --remove --force-remove-reinstreq <package>
s1mmel
  • 2,124
cd /etc/init.d/
get rid of the plex init entry
sudo mv plexmediaserver plexmediaserver.dead
remove it from update-rc
sudo update-rc.d -f plexmediaserver remove
Uninstall
sudo apt-get --purge remove -f plexmediaserver
delete the init.d entry
sudo rm -rf plexmediaserver.dead
