I installed dhcp3-server in ubuntu server 11.04
apt-get install dhcp3-server
However, an error message during installation:
Traitement des actions différées (« triggers ») pour « man-db »...
Traitement des actions différées (« triggers ») pour « ureadahead »...
Paramétrage de isc-dhcp-server (4.1.1-P1-15ubuntu9.1) ...
Generating /etc/default/isc-dhcp-server...
* Starting ISC DHCP server dhcpd
* check syslog for diagnostics                                   [fail]
invoke-rc.d: initscript isc-dhcp-server, action "start" failed.
Paramétrage de dhcp3-server (4.1.1-P1-15ubuntu9.1) ...
tail -f /var/log/syslog says:
Sep  2 03:29:20 srv dhcpd: Internet Systems Consortium DHCP Server 4.1.1-P1
Sep  2 03:29:20 srv dhcpd: Copyright 2004-2010 Internet Systems Consortium.
Sep  2 03:29:20 srv dhcpd: All rights reserved.
Sep  2 03:29:20 srv dhcpd: For info, please visit https://www.isc.org/software/dhcp/
Sep  2 03:29:20 srv dhcpd: Wrote 0 leases to leases file.
Sep  2 03:29:20 srv dhcpd: No subnet declaration for eth0 (192.168.1.1).
Sep  2 03:29:20 srv dhcpd: ** Ignoring requests on eth0.  If this is not what
Sep  2 03:29:20 srv dhcpd:    you want, please write a subnet declaration
Sep  2 03:29:20 srv dhcpd:    in your dhcpd.conf file for the network segment
Sep  2 03:29:20 srv dhcpd:    to which interface eth0 is attached. **
Sep  2 03:29:20 srv dhcpd: Not configured to listen on any interfaces!
Sep  2 03:29:23 srv kernel: [ 1625.286737] type=1400 audit(1314930563.298:18)            apparmor="STATUS" operation="profile_replace" name="/usr/sbin/dhcpd" pid=2045     comm="apparmor_parser"
when I want access to the file /etc/dhcp3/dhcpd.conf I can not find it but the package dhcp-server is installed.
  root@srv:/etc/dhcp3#ls -l
  total 4 drwxr-xr-x 2 root root 4096 2011-09-01 06:42 dhclient-enter-hooks.d
belacqua
  • 23,540
Try editing /etc/dhcp/dhcpd.conf instead. It should be installed along with the isc-dhcp-server package, and the dhcp3-server package which depends on it.
$ dpkg -S dhcpd.conf
isc-dhcp-server: /usr/share/doc/isc-dhcp-server/examples/dhcpd.conf
isc-dhcp-server: /etc/dhcp/dhcpd.conf
isc-dhcp-server: /usr/share/man/man5/dhcpd.conf.5.gz
belacqua
  • 23,540
To run a DHCP server you need to edit the file /etc/default/dhcp first and set the list of active network interfaces. On those interfaces DHCP will serve requests. Then you have to configure the server by editing /etc/dhcp/dhcpd.conf and adding appropriate "subnet" entry.
Kris Harper
  • 13,705
bofh
I suggest you follow this guide from the Ubuntu Wiki.
jrg
  • 61,707
