-1
thank you in advance.
I'm using Ubuntu 14.04 LTS and for somereason i can't get Adaptive readahead daemon to run, when i try to run it from terminal i encounter:
** (process:7371): ERROR **: cannot open /var/log/preload.log: Permission denied
Trace/breakpoint trap (core dumped)
EDIT :
In the app description in the Ubuntu Software Center in says : " this program is run from a terminal : preload "
so that's exactly whats i did, and got this message.
I could really use this application.
Does anyone has an idea?
how are you running it ?
should run as service ,
sudo service preload restart
or you can try ($USER can be replaced if you want to run with some other user )
sudo chown -R $USER /var/log/preload.log
