I have a Ubuntu 14.04 LTS System and I am not able to install Teamviewer 10 and is throwing :
dependency not satisfiable lib32asound2
Have somenone worked on it before?
First, download it:
wget http://www.teamviewer.com/download/teamviewer_linux.deb Now you have 2 options. You can use gdebi (recommended) to solve the dependencies, or you can solve them yourself.
Gdebi method:
First, install gdebi:
sudo dpkg --add-architecture i386 sudo apt-get update sudo apt-get install gdebi In the same directory you downloade the .deb file just run:
sudo gdebi teamviewer_linux.deb It will list the dependencies and install it with a y.
How about his one liner?
cd ~/Downloads/ && wget http://downloadeu2.teamviewer.com/download/version_10x/teamviewer_10.0.37742_i386.deb && sudo dpkg -i teamviewer* && sudo apt-get -y install -f
Open a Terminal and paste the command above into it. This should work for you!
What it does is change the current working directory to your Downloads folder, download the newest Teamviewer 10 (32/64 bit) .deb file and installs it via dpkg -i. After the installation fails (because of the dependencies) it installs all dependencies and Teamviewer itself via apt-get install -f (the -y option automatically accepts any question with yes).
