I just purchased a Lenovo Yoga 3, 14". It comes with a Qualcomm Atheros QCA61x4 wireless network adapter. I have not been successful getting this wifi to work. I have tried some suggestions for Yogas but they, apparently use a different adapter. I have also tried ndiswrapper without any luck. I downloaded a windows driver which installed fine and indicated that it found matching hardware, but still no wifi.
If I cannot get it working soon, I'll have to send the machine back. Life without Ubuntu is not to be considered. Any assistance would be greatly appreciated.
dos286
  • 51
I was able to get my Qualcomm Atheros 61x4 running on a ubuntu 15.04 clean install. Actually not for the Lenovo model but for an Acer Aspire VN7 Nitro 791G These are the steps I accomplished:
  • install kernel sources: apt-get install linux-headers-(uname -r)
  • downloaded the athk master sources from kvalo: git clone https://github.com/kvalo/ath.git
  • downloaded the backports tree: "git clone git://git.kernel.org/pub/scm/linux/kernel/git/backports/backports.git"
  • built the new backport tree according to the instructions found on linux-wireless: https://wireless.wiki.kernel.org/en/users/drivers/ath10k/backports
  • downloaded the firmware from sumdog and copied it to /lib/firmware/ath10k/QCA6174/hw2.1/ :
(Sorry I am not allowed to post more than two links)
"wget github.com/sumdog/ath10k-firmware/raw/5faf5bb7c7413f9bbde54cca6fff58e/ath10k/QCA6174/hw2.1/board.bin"
and
"wget github.com/sumdog/ath10k-firmware/raw/5faf5bb7c7413f9bbde54cca6fff58e/ath10k/QCA6174/hw2.1/firmware-4.bin"
  • created athk10 config file as described in this post before: sudo echo "options ath10k_core skip_otp=y" > /etc/modprobe.d/ath10k.conf
  • copied firmware-4.bin to firmware-5.bin as dmesg claimed about not finding firmware-5.bin
Hope this helps.
EDIT: The Intel 3160NGW card is the one to get for the Yoga 3 11 and Yoga 3 14. I did the replacement and can confirm it works. If you do this, make sure you get a card with FCC ID PD93160NGU, other IDs will not be recognized by the BIOS.
Original post: I've got a Yoga 3 11, which has the same Atheros card (QCA61x4). I've been tracking the driver issue closely, and it looks bleak. There is some movement for a QCA6174 driver, but I'm sort of sure it won't work for the QCA61x4 (different PCI listings -- 003e for 6174, 0041 for 61x4). I can imagine eventually we'll have linux kernel support, but it will be a while.
I like the computer a lot, so I'm keeping it. In the meantime, I'm using USB wifi, and I ordered a replacement intel wifi card (3160NGW). The yoga has a picky BIOS, and the 3160 is the one to get for our model based on reading Lenovo's published compliance documents. If you decide to replace the wifi card, make sure you get one with a matching FCC ID. For the 14 model, I would verify that the wifi also uses the M.2 connection. Good luck!
WakkaDojo
  • 101
On my machine Lenovo yoga 3 11:
uname -r
3.19.0-15
lspci -nn
...Qualcomm Atheros Device [168c:003e] (rev 20)
I fixed the problem like this.
But I booted from a USB stick with Ubuntu 15.04 so you will have to slightly adept the steps below for a full installation.
  1. Downloaded the driver from http://kernel.ubuntu.com/~adamlee/lp1383184/ath10k-dkms_1.1_all.deb
  2. Copy it to the stick. (I did it from Windows )
  3. Boot into Ubuntu and cd to the directory where you copied the file. (Hint: start looking for the files under /media/cdrom)
  4. sudo dpkg -i ./ath10k-dkms_1.1_all.deb
  5. Reboot
Hope this can fix it also for you!
