11
I use terminal so often for making quick commands and then I leave it in the background so that I end up getting 20+ terminal sessions open while I'm working. This is because it's very quick to simply use the shortcut key and type a command.
Is there a way to set up the shortcut key so I bring my up last terminal window instead of creating a new one?
αғsнιη
  • 36,350
Klik
  • 322
7 Answers7
13
I have a terminal pinned to my Unity launcher sidebar on position 10. This way I can press Super+0 to "click" the launcher icon which brings the latest terminal window to the top.
If having it in the launcher is ok for you (one of the first 10 positions, otherwise it won't get a shortcut!), this will work.
Byte Commander
  • 110,243
10
I use guake and I'm very happy with it. Press F12, a terminal window appears, press F12 again, it disappears but keeps running in the background. Also: looks really cool.
Jos
  • 30,529
  • 89
  • 96
You can put the script below under a key combination. If you press the key combination, the terminal window(s) will disappear (completely). Press it again, they will pop up again exactly in the state as you had it.
Only thing you need to to (once) is to add the identifying string in your terminal's window name (the terminal window has the same name in most cases)
To use it
Install both xdotool and wmctrl:
sudo apt-get install xdotool
sudo apt-get install wmctrl
  1. Copy the script into an empty file, save it as hide_terminal.py
  2. In the head section, set the identifying string of the terminal window's name
  3. Run it under a key combination:
    python3 /path/to/hide_terminal.py
The script
#!/usr/bin/env python3
import subprocess
import os
home = os.environ["HOME"]
hidden_windowid = home+"/.window_id.txt"
get = lambda cmd: subprocess.check_output(cmd).decode("utf-8")
# --- set the identifying string in the terminal window's name below (you mentioned "Terminal"
window_idstring = "Special_window"
def execute(cmd):
    subprocess.check_call(cmd)
w_id = [l.split()[0] for l in get(["wmctrl", "-l"]).splitlines() if window_idstring in l]
if len(w_id) !=0:
    for w in w_id:
        execute(["xdotool", "windowunmap", w])
        with open(hidden_windowid, "a") as out:
            out.write(w+"\n")
else:
    try:
        with open(hidden_windowid) as read:
            for w in [w.strip() for w in read.readlines()]:
                try:
                    execute(["xdotool", "windowmap", w])
                except subprocess.CalledProcessError:
                    pass
        with open(hidden_windowid, "wt") as clear:
            clear.write("")
    except FileNotFoundError:
        pass
Jacob Vlijm
  • 85,475
This is the same thing as Jacob Vlijm's answer, just written in bash:
#!/usr/bin/env bash
## window_name will be the first argument passed or, if no
## argument was given, "Terminal"
window_name=${1:-"Terminal"}
## Get the list of open terminals
terms=( $(wmctrl -l | grep "$window_name" | cut -d ' ' -f 1) )
## If all terminals are hidden
if [ -z "${terms[0]}" ]
then
    ## Read the IDs of hidden windows from .hidden_window_id
    while read termid
    do
        xdotool windowmap "$termid"
    done < ~/.hidden_window_id
## If there are visible terminals
else
    ## Clear the .hidden_window_id file
    > ~/.hidden_window_id
    ## For each open terminal
    for i in "${terms[@]}"
    do
        ## Save the current ID into the file
        printf "%s\n" "$i" >> ~/.hidden_window_id
        ## Hide the window
        xdotool windowunmap "$i"
    done
fi
If you save it as ~/bin/show_hide.sh, you can run it by giving the identifying string of any window you want to hide. If no string is given, it will work on Terminal:
show_hide.sh Terminal
terdon
  • 104,119
I'm using gnome-shell with 'Drop Down Terminal' extension, default shortcut is TAB but it's easily changed.
perdigueiro
  • 349
This simple wmctrl command will raise a window with a given string in the title or if no window exists containing the string, run a command.
wmctrl -a <str> || <command to launch application>
eg for gedit I can use
wmctrl -a gedit || gedit
To find a suitable string for your application window, open your application and run
wmctrl -l
Glen.S
  • 111
the following approach worked for me:
#!/usr/bin/env bash
# Written by Eric Zhiqiang Ma (http://www.ericzma.com)
# Last update: Jul. 9, 2014
# Read the tutorials at
# http://www.systutorials.com/5475/turning-gnome-terminal-to-a-pop-up-terminal/
# Required tools: xdotool
terminal="gnome-terminal"
stat_file="/dev/shm/actiavte-termianl.term.$USER"
termtype="Terminal"
wait_sec=1
max_wait_cnt=4
# parse options first
if [ "$1" != "" ]; then
    terminal="$1"
fi
term_exists () {
    allterms=`xdotool search --class "$termtype"`
    for e in $allterms; do [[ "$e" == "$1" ]] && return 0; done
    return 1
create_terminal () {
    echo "Create new terminal"
    $terminal --maximize &
    exists=1
    wait_cnt=0
    until [ "$exists" == "0" ]; do
        # sleep a while
        sleep $wait_sec
        # Note that the focus window may be from a terminal that
        # already exists; the makes create_terminal choose the existing terminal
        # Making the wait_sec large enough so that the terminal can be created and
        # displayed can make the false choosing more unlikely.
        term=$(xdotool getwindowfocus)
        term_exists "$term"
        exists=$?
        # avoid infinite wait
        let wait_cnt=wait_cnt+1
        if [ $wait_cnt -gt $max_wait_cnt ]; then
            echo "Wait for too long. Give up."
            term=""
            exists=0
        fi
    done
    echo "Created terminal window $term"
    # save the state
    echo "$term" >$stat_file
# read the state
if [ -f $stat_file ]; then
    term=$(cat $stat_file)
fi
# check whether it exists
term_exists "$term"
exists=$?
if [[ "$exists" != "0" ]]; then
    create_terminal
    exit 0
fi
# check whether it is already activated
curwin=$(xdotool getwindowfocus)
if [ "$term" == "$curwin" ]; then
    # deactivate (minimize) the terminal if it is currently activated
    xdotool windowminimize $curwin
else
    # activate the terminal if it is not currently activated
    xdotool windowactivate $term
fi
exit 0
then just give it execute permissions and bind the script to a key in settings.
source:
