I am using ubuntu 14.10. I am trying to install all updates, but it's show me the following result:
The package system is broken
Check if you are using third party repositories. If so disable them, since they are a common source of problems. Furthermore run the following command in a Terminal:
apt-get install -f
Details:
gcc-4.9-multilib: Depends: gcc-4.9-base (= 4.9.1-16ubuntu6) but 4.9.1-16ubuntu6 is installed
Depends: gcc-4.9 (= 4.9.1-16ubuntu6) but 4.9.1-16ubuntu6 is installed
Depends: libc6-dev-i386 (>= 2.11) but it is not installed
Depends: lib32gcc-4.9-dev (= 4.9.1-16ubuntu6) but 4.9.1-16ubuntu6 is installed
Depends: libx32gcc-4.9-dev (= 4.9.1-16ubuntu6) but 4.9.1-16ubuntu6 is installed
libc6-dev-x32: Depends: libc6-x32 (= 2.19-10ubuntu2.3) but 2.19-10ubuntu2.3 is installed
Depends: libc6-dev-i386 (= 2.19-10ubuntu2.3) but it is not installed
Depends: libc6-dev (= 2.19-10ubuntu2.3) but 2.19-10ubuntu2.3 is installed
Then I removed the third party repositories and run the command in terminal sudo apt-get -f install. But after all I got the following error:
dpkg: error processing archive /var/cache/apt/archives/libc6-dev-i386_2.19-10ubuntu2.3_amd64.deb (--unpack):
trying to overwrite '/usr/include/fpu_control.h', which is also in package libc6-dev-amd64 2.19-10ubuntu2.3
So, now I need the person who can fix the problem. Great pleasure if you can help me to get out this problem. Please...
