my computer is prone to over-heating and so I'm trying to control the fan speeds. I've researched a little and I'm blocked How to control fan speed? and then installed lm-sensorsand fan control.
I'm now trying to configure lm-sensors to no avail. In terminal I typed sudo sensors-detect and answer YES to all YES/no questions. Installed modules with sudo /etc/init.d/kmod start. Now when I type sudo pwmconfig I get this output
     /usr/sbin/pwmconfig: There are no pwm-capable sensor modules installed
The way I tried to fixed this is to edit /etc/default/grub to add acpi_enforce_resources=lax to the GRUB_CMDLINE_LINUX_DEFAULT and then perform a grub update. I'm still having the same issue. This is the output of the sensors command.
acpitz-virtual-0
Adapter: Virtual device
temp1:        +50.0°C
coretemp-isa-0000 Adapter: ISA adapter Physical id 0: +49.0°C (high = +84.0°C, crit = +100.0°C) Core 0: +48.0°C (high = +84.0°C, crit = +100.0°C) Core 1: +45.0°C (high = +84.0°C, crit = +100.0°C) Core 2: +46.0°C (high = +84.0°C, crit = +100.0°C) Core 3: +44.0°C (high = +84.0°C, crit = +100.0°C)
Can anyone help me? Thanks.
It appears the fans inside the computer are not PWM or Pulse-width modulation.
Common cooling fans used in computers use standardized connectors with two to four pins.
PWM use a 4 pin connector and can be controlled by software.
The first two pins are always used to deliver power to the fan motor.
3 pin connectors don't have PWM 3-pin fan speed is controlled by voltage.
damien
  • 2,116
