I have a 500gb external hdd that I'm using to boot Ubuntu. I don't need 500gb it was just so I didn't mess up my internal drive running OS x. I just bought a 64gb usb that I would like to make bootable with all the stuff from my external drive(only using lk 18 gb). Everything website I've found says I need 500gb(same size) or bigger to clone the drive and settings. Is there any way to make the 64gb drive bootable by cloning from my external drive?
You really have two options:
  1. You could copy all the deb files for the packages you have installed from /var/cache/apt/archives just so long as you haven't ran sudo apt-get clean to specifically remove these files
  2. I have always used aptoncd which is my recommendation.
Just open a terminal and run the following command:
sudo apt-get update && sudo apt-get install aptoncd
From their webpage:
Create a removable repository with all packages downloaded with Synaptic, apt-get or aptitude.
This gives you a fancy GUI to make backups of all your programs, it is capable of others things as well but this is what I have always used it for. Here is their website.
Dylan
  • 384
