So, my laptop died. I have an old netbook. It has Ubuntu 10.04, and the upgrade manager says I can install 12.04. My question is, will this netbook run smoothly with it? Also, will it support newer versions?
The netbook is a Point of View Mobii 9040, with these specs:
  • Processor:Intel Atom N450 1.66 GHz
  • Chipset:Intel NM10 Express Chipset
  • Graphics chipset:Intel GMA 3150
  • Storage:250GB SATA
  • RAM:1GB DDR2 SDRAM
  • LAN:RJ45 10/100Mbps
Thanks!
Molina
Probably Lubuntu 14.04 LTS is a better choice for it.
I recommend you to make a bootable USB-Flash with Lubuntu on it, and try it first without installation. If it will run correctly, then you can perform the installation from it.
user300458
  • 2,138
It will run and everything will work. However Unity has some effects that drag down even my new up to date desktop, so I can't imagine what it would do to your laptop. If it is a matter of performance I would recommend Lubuntu or even better Puppy Linux, which is specially built to be an OS meant for lower end/old computers. I think you would find the transition very easy and worthwhile. You might consider doing a live USB/CD before committing. Take them both for a test drive and see what you think.
Here is puppy linux :)
Good Luck!
Dylan
  • 384
