Just switched to ubuntu 14. I tried to install Singular (CA system) without success. Here the owner manual
Step-by-step instructions for Ubuntu 14.04:
  • Add gpg key:
    • wget ftp://jim.mathematik.uni-kl.de/repo/extra/gpg
    • apt-key add gpg
  • Add deb ftp://jim.mathematik.uni-kl.de/repo/ubuntu14 trusty main to /etc/apt/sources.list
  • apt-get update
  • apt-get install singular
Here what I did so far:
 ~$ wget ftp://jim.mathematik.uni-kl.de/repo/extra/gpg
 ~$ sudo apt-key add gpg
 ~$ deb ftp://jim.mathematik.uni-kl.de/repo/ubuntu14 trusty main
  ~> No command 'deb' found...
Any help would be greatly appreciated!
0x2b3bfa0
  • 9,110
  • 38
  • 55
J.M.P.
The step-by-step instructions for Ubuntu 14.04 said to open the sources.list file located at /etc/apt/sources.list for editing. You can open the sources.list file for editing in nano text editor using this command:
sudo nano /etc/apt/sources.list
Add this line to sources.list:
Press the keyboard combination Ctrl+O and after that press Enter to save the changes in sources.list.
Press the keyboard combination Ctrl+X to exit nano.
Then run these two commands to update the latest list of software and then install singular:
sudo apt-get update
sudo apt-get install singular
If you get this error when trying to use apt-get:
E: Could not get lock /var/lib/apt/lists/lock - open (11 Resource temporarily unavailable)
...the instructions for fixing it are at this question:
Unable to lock the administration directory (/var/lib/dpkg/) is another process using it?.
karel
  • 122,292
  • 133
  • 301
  • 332
The instructions said to open the sources.list file located at /etc/apt folder and append to it the deb ftp://jim.mathematik.uni-kl.de/repo/ubuntu14 trusty main line.
The easiest procedure is to replace this step with this command that does it for you:
sudo add-apt-repository "deb ftp://jim.mathematik.uni-kl.de/repo/ubuntu14 trusty main"
0x2b3bfa0
  • 9,110
  • 38
  • 55
