I'm using Ubuntu 14.04 and the last released library 1.0.0. I'm a beginner.
First I can't install freeglut3-dev.
I tried to solve it from the other question Installing freeglut3-dev on Ubuntu 12.04.4 but it doesn't work. Please don't mark it duplicated.
This error appears with 2 dependencies. I INSTALL them but doesn't work.
some packages could not be installed. This may mean that you have
unity-control-center : Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
Depends: libcheese7 (>= 3.0.1) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Second (I think the cause of the second one is the first one:
When I tried to install the ompl library, the cmake compile step after writing make it comes with this error:
[ 92%] Building CXX object src/omplapp/CMakeFiles/ompl_app.dir/graphics/detail/assimpGUtil.cpp.o
/home/obuntu/omplapp/src/omplapp/graphics/detail/assimpGUtil.cpp:18:19: fatal error: GL/gl.h: No such file or directory
#include <GL/gl.h>
compilation terminated.
make[2]: *** [src/omplapp/CMakeFiles/ompl_app.dir/graphics/detail/assimpGUtil.cpp.o] Error 1
make[1]: *** [src/omplapp/CMakeFiles/ompl_app.dir/all] Error 2
make: *** [all] Error 2
