Most of the films I watch on my PC are in HD, those of 20GB or more, even between 50-72GB. On Windows I can play all those films without problem.
Some of them are .mkv and others are bdmv.
I did not install any driver from catalyst or from Additional Drivers. Nevertheless I have direct rendering:
mortuus@alliancecore:~$ glxinfo | grep direct
direct rendering: Yes
I've tested it with VLC 1.1.9 (with and without GPU acceleration), smplayer, totem and moovida center. None was successful.
My specs:
  • AMD Phenom II X4 905e 2'5GHz
  • RAM 4GB
  • ATI Radeon HD4890
  • My resolution is 1920x1080
Thanks in advance
jrg
  • 61,707
aesptux
  • 19
Well, i already had that problem in my pc. what i did was to install SmPlayer and configuring it. Going menu, preferences,general, and in the video tab, select (gl- fast- Ati cards). then when you want to see a movie open it with smplayer and i think it will be fixed. If not, tell-me something.
Celso
  • 432
-1
Hi i have a simular setup and also got lag with my screen resulotion at 1920 x 1080 because i only could pick 25 Hz and 30 Hz maximum. The TV got the 1080i singal
I have changed my 1280 x 768 at 60 Hz and no lag anymore... also widescreen option in totem player made my TV work at 1080i (hd ready TV) at this resolution.
i chose to go for an image without lag instead of full pixels at 30 Hz with a little lag. My screen is 108 cm in with.
Dennis
