Ubuntu Vivid uses systemd, however I don't have a clue how it exactly works. Can maybe someone write the correct kodi.service file what needs to be placed in /etc/systemd/system thanks a lot.
peelman
  • 133
A more comprehensive guide.
Assumptions:
Starting with a naked Ubuntu Server; only SSH installed. Configuration done via SSH from another machine, not locally.
Install Kodi and pre-reqs:
sudo apt-add-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get install xinit kodi
sudo apt-get install xserver-xorg-video-intel # If you need the Intel video package)
Create a kodi user & set groups:
sudo adduser --disabled-password --disabled-login --gecos "" kodi
sudo usermod -a -G audio kodi
sudo usermod -a -G video kodi
sudo usermod -a -G input kodi
sudo usermod -a -G dialout kodi
sudo usermod -a -G plugdev kodi
sudo usermod -a -G tty kodi
Reconfigure X11 to allow kodi to use it
dpkg-reconfigure x11-common # Change to Anybody
Create / Edit the Kodi Service
sudo nano /etc/systemd/system/kodi.service
Should look like this: (via @SauliusZ)
[Unit]
Description=Job that runs Kodi
After=default.target graphical.target getty.target sound.target
[Service]
User=kodi
Restart=always
RestartSec=1s
ExecStart=/usr/bin/xinit /usr/bin/kodi --standalone -- -nocursor
[Install]
WantedBy=default.target
Reload and enable the daemon
sudo systemctl daemon-reload
sudo systemctl enable kodi
Test Kodi
sudo service kodi start # should launch Kodi
sudo service kodi stop # should stop Kodi
Reboot to make sure it runs at boot
peelman
  • 133
I installed Kodi using this guide on Ubuntu Server 15.04
And then by try and error came up with this.
[Unit]
[Service]
User=kodi
Restart=always
RestartSec=1s
[Install]
I am not sure about WantedBy part, but it works, and you're welcome to improve my code.
